SLU removal - Defender Source
Old December 29th, 2009, 12:18 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
SLU removal
Can anyone tell me what size spanner is needed to get the SLU cylinder out of the rear a-frame? Just need to replace both gaiters. Any other suggestions on how to make it a bit easier would also be great. It is not so easy to find tappet spanners around here so will need to grind down a normal one to the right thickness, just want to be certain I am starting with the correct one. This is the last bit before my rear suspension is complete. (then should finish the front this week after I get a set of wide radius arms to match the new front axle housing, yay!)
Will sure be nice to be able to roll it around a bit.
Belt removal on a 97 thelandroverguy Defender Technical Discussions 10 July 31st, 2011 09:41 PM
For Sale Bulkhead removal bar TDI Guy For Sale - Parts 11 February 2nd, 2005 08:57 AM
D90 wgn - Automatic Shifter T- Handle Removal Kimos Defender Technical Discussions 22 January 18th, 2005 07:05 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
