Slow oil leak, is this a problem? - Defender Source
Old February 20th, 2016, 12:48 PM
ymc226
Lawrence
1995 D90 SW NAS
Haven't driven since end of November to keep the frame from rusting and have noticed more of a very slow drip on the driver side of what I think is an oil line. It's very slow but still more than what I remember when I did drive it daily and kept cardboard underneath which stayed mostly dry.
If most think it is "normal", I'll just live with it as I know most Rovers leak a little.
Name:	defender leak-2.jpg
ID:	142848   Click image for larger version
Name:	defender leak-3.jpg
Old February 20th, 2016, 01:00 PM
Cold weather makes seals shrink which makes things leak. Have you tried tightening the jubilee clamp? Also are you sure that is where it is leaking from? With that said, it's a Landy and they do leak.
Old February 20th, 2016, 06:37 PM
Man that's not a leak
Old February 20th, 2016, 06:53 PM
Originally Posted by ymc226 View Post
Haven't driven since end of November to keep the frame from rusting and have noticed more of a very slow drip on the driver side of what I think is an oil line. It's very slow but still more than what I remember when I did drive it daily and kept cardboard underneath which stayed mostly dry. If most think it is "normal", I'll just live with it as I know most Rovers leak a little.
Looks like a power steering hose to me. Especially as the 'oil' looks red.
Put a turn on the hose clamp and don't worry about it. The whole reason the front of my frame is in perfect condition is due to a power steering slow leak probably from new!
Old February 20th, 2016, 07:05 PM
ezzzzzzz
Mark Garrenton
Only worry when it isn't leaking. That would mean it is out of fluid.
I need to go back to work for the break. Retirement is exhausting!
'71 IIA 88" LS1 hybrid
'84 110 5 door 'Nigerian Princess'
'90 RRC
'97 D1 LSE (parting out)
'02 D2 Kalahari
'02 D2 SE
'02 D2 SE
Old February 20th, 2016, 07:25 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I would sell it... Just saying who wants a truck that leaks like that?
Old February 20th, 2016, 07:49 PM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
Old February 20th, 2016, 07:59 PM
Chowbird's Avatar
Chowbird
Tim
'84 D90
Something's missing...the dirt, grime, filth, sludge, muck......
1984 D90 LHD 3.5 V8
2010 Range Rover Sport
Old February 21st, 2016, 12:19 AM
Should give it away ...
Old February 21st, 2016, 12:58 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
That's not a leak.
Now THAT's a leak!
Old February 21st, 2016, 01:30 AM
Originally Posted by D90Overkill View Post
That's not a leak. Now THAT's a leak!
That's not a leak.
That's a fire hazard.
Old February 21st, 2016, 01:44 AM
D90Overkill
David Frank
1995 ST #2615
Haha! Yup. It was. This was on Rusty before I got to work. Sure was a nice frame once I found it! ;-)
Old February 21st, 2016, 07:22 AM
lolololol
Old February 21st, 2016, 08:34 AM
that's a persistent drip not a leak.
Old February 21st, 2016, 08:41 AM
It's like a dog that constantly drools.
Old February 21st, 2016, 05:05 PM
ymc226
Lawrence
1995 D90 SW NAS
Thanks Dave and Jason,
I think you're right Jason; the fluid was red so likely power steering. Just tightened up and wiped the reservoir and hose clean. Will observe for further dripping. Otherwise the bottom of the truck is very clean.
Is there a product I can spray on and rinse off with a hose to completely clean the bottom side? I have this OCD trait in wanting this part of the truck spotless?
During the winter, completely detailed the paint with shampoo, clay, iron remover, polish with dual action orbiter and finished off with paint sealant. The paint now looks almost like the day it was delivered. Also polished as much of the glass with polishing agent and DA given mineral deposits that wouldn't come off otherwise.
Old February 21st, 2016, 08:23 PM
Thanks Dave and Jason, I think you're right Jason; the fluid was red so likely power steering. Just tightened up and wiped the reservoir and hose clean. Will observe for further dripping. Otherwise the bottom of the truck is very clean. Is there a product I can spray on and rinse off with a hose to completely clean the bottom side? I have this OCD trait in wanting this part of the truck spotless? During the winter, completely detailed the paint with shampoo, clay, iron remover, polish with dual action orbiter and finished off with paint sealant. The paint now looks almost like the day it was delivered. Also polished as much of the glass with polishing agent and DA given mineral deposits that wouldn't come off otherwise.
Can I lend you my truck?
Old March 24th, 2016, 03:25 PM
Grover's Avatar
Grover
That's not a leak.
Now THAT's a leak!
That's preservation.
Old March 24th, 2016, 08:36 PM
that buffer will burn the paint off the truck. Simple greeen is an excellent degreaser, if that bothers you then you should reconsider owning and land rover
Old March 26th, 2016, 12:12 AM
akrockhound's Avatar
akrockhound
Jack
1988 RHD 110
not a leak
Well we can all agree that's not a leak by Rover standards. But if its power steering hose do keep an eye on it. If its the high pressure one it can go quickly and when it does it is a fire hazard.
Looks like the crimp might be leaking - they all do given enough time and the cold is especially hard on them.
But I agree, that's not a leak
'88 ROW 110 5-door SOLD
'01 Disco II
'95 RRC LWB
Oil Leak..Oil Pressure Switch Failure? tebby Defender Technical Discussions 2 December 19th, 2010 03:16 PM
slow coolant leak defender1844 Defender Technical Discussions 11 June 18th, 2008 05:03 AM
I think I fixed my SW roof leak problem BarryO Defender Technical Discussions 12 November 20th, 2006 08:01 AM
Reverse Light is Slow to Turn On-Why? JRowe Defender Technical Discussions 1 December 12th, 2003 05:03 PM
