slow coolant leak - Defender Source
Old January 7th, 2008, 06:29 PM
defender1844
Amit Likhyani
slow coolant leak
Couldn't find this in search. I apologize if it's already out there. I have a 1997 D90 with 109k miles on it. The radiator had sludge and was sent out to a radiator shop a year and a half ago. Just to give some background. Now, every 4 months I need to add 1/2 gallon of antifreeze after the needle moves up. This solves the problem for a little while. I don't see coolant on the ground although occassionally I can smell it. What is the best way to diagnose this? I am hoping it's a connection or hose and not an internal water jacket or head gasket. But I am prepared for whatever.
Old January 7th, 2008, 06:51 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
can you see any little puddles under the hood?
Old January 7th, 2008, 07:33 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
might be a leaky expansion tank??
~Steve
Old January 7th, 2008, 08:23 PM
imola's Avatar
imola
check the water pump as well.
Old January 7th, 2008, 08:24 PM
Heater core ? This are famous leaking points on Range Rover classic's
Old January 7th, 2008, 09:59 PM
Grover's Avatar
Grover
Is it possible that it is running down the block and buring off? Look under the motor and inspect the head and block mating surfaces...
Old June 13th, 2008, 01:38 PM
Turd Ferguson's Avatar
Turd Ferguson
Frank
94 D-90
Iam experiencing the same problem and cant figure out what to blame it on. Did you ever diagnose the problem?
Old June 13th, 2008, 02:04 PM
When the car is running, is the upper radiator hose pressurized? If not, I am going with the water pump is leaking. Also check the back of the block as the intake gasket and head gaskets like to leak. Heater cores on D90s do not seem to be a huge problem issue, but you could bypass it easy enough to check.
Ron
Old June 13th, 2008, 02:05 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Could also be a porous block ( worst case scenario ) ex: coolant leaking into combustion chamber and being burned away. It's rare but possible if nothing else seems to make sense. It's also my understanding that if you get a porous block you have to buy a new one.
Robert Deniro
Old June 13th, 2008, 02:21 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
If you can smell it, then its evaporating somewhere.. this means its running or dripping on the engine. Might also be a leaking heater core, you'd smell it when you run the heat.. Check the thermostat housing, maybe the waterpump.
~Steve
Old June 13th, 2008, 02:28 PM
Gore Ranger
Jeff
1989 RRC
I have had problems with my range rover in the past.
Twice it was as simple as the hose clamps had loosened. Once it was a bad hose that must have had a pin hole in it.
One other time, my water pump was leaking through the purge valve. If it is the water pump, you would definitely see coolant on the ground in my experience. Every time I parked, it spewed out some water on the ground.
However, in all the instances, the radiator still cooled the water adequately.
If the temp is rising, your radiator might be due for a replacement. I had mine flushed at one point but that only seemed like a stopgap.
What I was told that worked for me was to idle the truck until it reaches temperature and observe under carefully under the hood.
Old June 18th, 2008, 05:03 AM
defender1844
Amit Likhyani
I got my truck to start again. It was the connector to the fuel pump. Big props to Atomic 4x4 in Cedar Park, TX. They specialize in Jeeps and do great work on them. As a favor they have done some work on my Defender as my former employer was 2 miles from their shop. With that plug out of the way, the next issue is the slow coolant leak. Since there are drops under the truck, I think it's a water pump leaking as this is the stock water pump on a truck with 112,000 miles on it. Is there a better source than Rover's North for $278? I'll take used and working perfectly.
coolant
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant Leak - Help! mlw911 Defender Technical Discussions 6 March 15th, 2006 11:08 AM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
coolant leak jperakis Defender Technical Discussions 2 February 27th, 2005 02:39 AM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
