Sloppy Steering - Defender Source
Old July 14th, 2006, 10:53 PM
fleabus's Avatar
fleabus
Dan
None :(
Sloppy Steering
I have had a SG Stage II lift on my D-90 for a while and just recently the steering has become pretty sloppy (wandering).
After the lift, I added some RTE rear links to fix a vibration issue, but never got around to dealing with the front.
What should I be looking at?
Radius Arms
Adjustable Pan Hard Rod
Stabilizer
I suspect it is just bushing bind/wear on the front axle, but I thought I would ask.
Any advice would be appreciated.
Cheers!
-Dan
Old July 14th, 2006, 11:34 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
most likely it's going to be the tie rod ends and the drop-arm ball joint. About $80 for the parts to replace all 4 joints. Have somebody else turn the steering back and forth and you should see if the joints are getting sloppy pretty easily.
-Hans
My oil line fix
My 100k stopped odometer fix
Old July 15th, 2006, 12:32 AM
fleabus's Avatar
fleabus
Dan
None :(
-Hans
Thanks Hans... I'll give it a look tomorrow.
Old July 15th, 2006, 05:18 AM
i thought lifts messed up castor? hence making steering and self centereing bad?
Old July 15th, 2006, 07:40 AM
I had that problem a few years back... I had an alignment done, thinking something was off, that did not fix the problem. We found out that the large nut on the Radius Arms were loose.
Once we tightened them up everything went back to normal.
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Steering wheel adapters Buckon37s Defender Technical Discussions 109 July 1st, 2007 09:19 PM
Steering problem! TwisteD90 Defender Technical Discussions 3 June 2nd, 2005 02:55 AM
Loose steering kellymoe Defender Technical Discussions 2 October 15th, 2004 08:42 PM
