Slop in swivel ball - Defender Source
Old December 6th, 2014, 02:23 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Slop in swivel ball
I was rotating my tires and found some play in the swivel housing. When I jack up the front left I can get movement when I push in at the top of the tire. Looking at it from the axle side, everything moves outside of the chrome swivel. Any thoughts for a fix?
I took some video that I'll try to get on here later.
Old December 6th, 2014, 02:29 PM
play in the bearings hopefully.
try pulling some shims out from under the top pin and see if that cures it.
Failing that, you are due a rebuild of the swivel setup. Not that big of a deal really, just a lot of bolts, as someone said here recently.
Old December 6th, 2014, 02:40 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Man I hate it when that happens...
Have you been off road lately? when was the last time you serviced any of those components? preload? ball juice?
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Ok thanks. Fwiw, the play only seems to be up and down, not side to side.
This should work for the video
Old December 6th, 2014, 02:41 PM
And in case it wasn't obvious, the first thing you should try is tightening the hub nuts. It's quick and easy.
Originally Posted by pendy
I'm here for the D's
Old December 6th, 2014, 02:45 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Honestly I was being a little lazy. I didn't want to pull the spacer and dig deeper because that would require me to actually get out the tool box and I'm supposed to be working.
I should do some legwork so as to narrow it down I guess
------ Follow up post added December 6th, 2014 02:54 PM ------
Originally Posted by Bill Larson View Post
Man I hate it when that happens... Have you been off road lately? when was the last time you serviced any of those components? preload? ball juice?
Just Uwharrie in October. I gave it ball juice but all the rest should be serviced. I put new rotors and pads on a while back but didn't dig much further. I don't like these older style rotors and I have sticky caliper that puts up a fuss occasionally.
Old December 6th, 2014, 02:58 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Upper pin looks wasted to me , but a shim or two may take some out but I'd pull it apart and inspect for wear in the Railco and pin . The lower bearings are normally the last to go as they are always in grease being at the bottom . Unless your swivels are full of water from wheeling ;-) .
85 D110 3.5 3 DR
Old December 6th, 2014, 03:26 PM
Hey Captain,
Hub nuts do not affect the swivel pins. He said everything is moving including the outboard swivel housing.
FYI if you're not sure where the play is, block the brake pedal down and the clamping of the brake pads on the rotor will lock out any play in the hub bearings.
IOW if the play is gone with the brake pedal pressed down, your problem is in the wheel bearings. If not, then it is in the swivel.
Way easier than removing the drive flange.
Old December 6th, 2014, 03:36 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Top/bottom play without side/side play is swivels. Play in al directions is wheel bearings.
Old December 6th, 2014, 03:40 PM
aka rover's Avatar
aka rover
ed angel
95 D90
guys theres a video :-)
85 D110 3.5 3 DR
Old December 6th, 2014, 04:29 PM
Yeah video got posted after my last post. I see both the tie rod and the radius arm moving - so the whole axle may be shifting! It looks to me like you have a whole lotta stuff loose under there. I'd start by checking the bushings and ball joints.
Old December 6th, 2014, 07:44 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I have a front axle housing complete from end to end with slotted rotors that I think came off a RRC. Can I refurbish that and swap it in? I believe it has the two pipe calipers which I'm not sure how to deal with.
You're right Galpin, there is a lot of loose stuff there. I think it's time to get all new bushings as well.
Old December 6th, 2014, 08:26 PM
There are two different width of radius arms, so it will depend if they are the same as your Defender which likely has the more narrow ones. The frame mount is also smaller on the older ones.
------ Follow up post added December 6th, 2014 08:27 PM ------
That's not 100% true, the brakes can make it feel like there is no side to side play, when there probably should be. This is especially true if you have a slightly sticking calliper.
Old December 6th, 2014, 08:56 PM
Jeff:
Rebuilding the swivel ball is a piece of cake, I just did mine on the 90 (I was getting a small leak of 90W at the bottom of the seal that was driving me crazy). I replaced the seal awhile back, but then it started leaking again so I just decided to pull it all apart and rebuild. Call or text me, I can give you all the part #'s needed and walk you through it.
Old December 6th, 2014, 09:12 PM
thats some gnarly slop, man just get everthing from the swivel pin out, rebuild it all on the work bench and bolt it on the axle
Old December 6th, 2014, 11:22 PM
The radius arm bushings look shot too.
Old December 6th, 2014, 11:26 PM
Bill Larson
Bill Larson
Quit running those NC moonshine trails! Dang Redneck...
Old December 6th, 2014, 11:51 PM
Bill Larson
Bill Larson
good catch.
Honestly Im surprised this isn't a death wobble thread.
-Jeff
Well that was to come right? because as he starts "correcting" the problem others will come to light. With the steering it's never just "one" thing it's usually a few, one wears another until the failure is evident. then comes the elimination...
Old December 7th, 2014, 01:07 AM
Thankfully steering dampeners exist!
Old December 7th, 2014, 01:14 AM
Bill Larson
Bill Larson
X3...the steering band aid! I was told to remove it and see what happens! yeah thats kinda scary to just think about! lol...Do that and you'll find more than you thought.
What's up with the Slop in the Drivetrain? spencer08291985 Defender Technical Discussions 75 June 17th, 2015 08:32 PM
R380 Shift Lever Slop geoellis Defender Technical Discussions 8 March 28th, 2014 10:04 AM
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
Driveline slop chris snell Defender Technical Discussions 8 June 26th, 2011 02:44 PM
Maya Culpa series 3 Question about main shaft slop in gearbox airbornrover Series Technical Discussions 2 May 21st, 2009 08:09 PM
