Slop in swivel ball - Page 2 - Defender Source
Old December 7th, 2014, 07:55 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Originally Posted by Bill Larson View Post
Well that was to come right? because as he starts "correcting" the problem others will come to light. With the steering it's never just "one" thing it's usually a few, one wears another until the failure is evident. then comes the elimination...
And I thought I was doing good by rotating the tires.
Old February 5th, 2015, 11:53 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Finally picking this up again I have removed both pins but this early axle has the bushing in the top of the swivel that's inside of the housing. I can't pull the housing off because its interfering with the bushing. I can only guess that it is contributing to the slop, because it is rather sung in the swivel, but I can't tell until I get it out. It doesn't appear that I can get it out of the hole in the top of the housing.
What am I doing wrong? A couple guys said this was an easy job so I must be going at it the hard way but it seems to be the only way.
ID:	112861   Click image for larger version
Old February 5th, 2015, 12:02 PM
Have you pulled out the bottom pin? Swivel seal off?
You need to remove the swivel from the axle anyway to replace the swivel seal, so get that off and the whole mess on the bench.
did you take the oil seal retainer and oil seal out?
Old February 5th, 2015, 12:15 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Both pins are out and the metal rings are off the back but the rubber seal is still in place. I'll pull the whole thing from the axle and dig deeper.
Thank you
Old February 5th, 2015, 12:30 PM
It won't come off with the seal in place. Follow the manual.......
What's up with the Slop in the Drivetrain? spencer08291985 Defender Technical Discussions 75 June 17th, 2015 08:32 PM
R380 Shift Lever Slop geoellis Defender Technical Discussions 8 March 28th, 2014 10:04 AM
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
Driveline slop chris snell Defender Technical Discussions 8 June 26th, 2011 02:44 PM
Maya Culpa series 3 Question about main shaft slop in gearbox airbornrover Series Technical Discussions 2 May 21st, 2009 08:09 PM
