slight surging of engine power - Defender Source
Old January 26th, 2008, 11:04 PM
matthewwcarey's Avatar
matthewwcarey
Matthew Carey
95 D90 SW349
Need some diagnostic advice, 95 SW on the highway, 2,100 rpm and 5th gear. Turn on the blower fan to its highest setting and there is a slight surging of engine power, select lower fan speed and surging goes away?
Thanks Matthew
Old January 28th, 2008, 03:42 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Sounds like you have a problem with your alternator--probably your Zenier diodes. Almost sure of it. As the diodes fail, you start bleeding A/C into your system and it is causing your fuel injectors to fire irregularly--somehow the added load on the alternator from your blower is causing it.
Granted, this is conjecture, but it is an educated guess.
Old January 28th, 2008, 07:05 PM
matthewwcarey
Matthew Carey
95 D90 SW349
Chris, thanks for your reply, it's a brand new alt maybe 150 miles on it. Do you think it could be a defect or mis-installed?
Thanks Matthew
Old January 28th, 2008, 09:43 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Surging with powering an electrical device leads me to believe the electrical system is playing on the fuel delivery system. I would totally check the alternator first thing--especially if this problem started after receiving it.
The only other thing I can think of is possibly causing a big pressure differential from the fuel pump, but that just doesn't feel right. Surging is usually fuel delivery issue and tying that to the heater motor leads me to think it is electrical. Now knowing you have a new alternator, it makes me think that more strongly.
Interesting issue--please let us all know what you find out.
Old January 29th, 2008, 10:05 PM
matthewwcarey
Matthew Carey
95 D90 SW349
Thanks again for your help, if I come up with anything all post my findings.
Matthew
Old September 26th, 2008, 10:05 AM
Chris Vitale's Avatar
Chris Vitale
'95 D90 ST 2.8L TDi #2050
I am having the same issue. Was the alternator the problem or was it fuel related?
Thanks.
Old September 30th, 2008, 12:56 PM
Chris Vitale
Thanks for the help Chris Davis.
I just replaced the alternator with a refurbish alternator and I have been unable to recreate the surging issue mentioned earlier! The real test will be on Thursday's ride down to MAR. Hopefully the trip will be uneventful...Well then again, why did I get a D-90. Itís not about the destination right???
On another note, I would like to keep my old alternator as a spare. Does anyone have a recommendation for refurbishing my old alternator? Do it myself? have an experienced shop do it? If done by an experienced shop, do you recommend anyone?
Old September 30th, 2008, 11:25 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Chris... BonJourno... There is a place right by me that I use to rebuild that stuff.. let me know...
Legend in My Own Mind.
Old October 1st, 2008, 12:13 AM
everglades
Nando Zorrilla
1995/Defender
I suspect the power surge comes from that vibrator you keep plugged into your cigarette lighter.
In any case, I suspect that the reason you have a brand new alternator is because the last owner was chasing the same issue and replaced the alternator without need.
We should put a volt meter on the electrical system and see what kind of voltage drop you get when you run the blower. We can compare it to my truck and determine if we need to keep looking at the electrical system or look elsewhere. It it drops severly, we can put an current meter on the blower leads and determine if the blower is drawing too much current.
Old October 1st, 2008, 12:26 AM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
Randy -- Where abouts? I have a D2 alt. that needs a rebuilding.
-Ryan
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old October 1st, 2008, 09:39 AM
Chris Vitale
It wasn't a new alternator. I replaced the original alternator with a refurbished alternator and I think the problem is solved. If I experience any problems during the MAR trip, I will follow your suggestion. Thanks.
By the way...I highly recommend keeping a charged vibrator in your D-90. It's a great conversation piece that quickly breaks the ice and it doubles as a useful tool to breakaway the Virginia mud that gets caked up in the radiator.
engine, ht
Experiencing wierd electrical problems, engine power issues? madcowdungbeetle Defender Technical Discussions 0 May 26th, 2008 10:14 PM
Loss of power Leadfoot Defender Technical Discussions 4 January 28th, 2005 03:36 PM
