Sliding windows on NAS Fiberglass hardtop? - Defender Source
Old March 2nd, 2016, 04:40 PM
dlee888
Davie Lee
1997 D90 Soft Top
Has anyone ever modified the windows in a factory hardtop with sliding windows?
The dimensions are exact, but wasn't sure about overall fit...
Thanks!
Name:	D90 sliding windows.jpg
Old March 2nd, 2016, 05:02 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
I don't imagine why not? I was planning on it, as well. It was an option for D90Tops (aftermarket).
Old March 2nd, 2016, 09:15 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
What holds the original fixed panels in the fiberglass, a rubber seal??
The sliders are held in with pop rivets around the perimeter, about 22 in all.
In fiberglass, the rivets would require the "metal washers" for the rivet to squeeze to in the installation process. The rivets would have to be longer also to go through both the fiberglass & the metal washer/backer.
Old March 2nd, 2016, 09:18 PM
D90Overkill
David Frank
1995 ST #2615
These appear to be 24 rivets each (doesn't matter). I'd be surprised if a finishing frame wasn't available for the inside to act as a sandwich plate for the rivets. All that being said, once installed, I don't believe you could ever go back, as the rubber gasket might not be thick enough to cover the rivet holes. Then again, why would you ever want to go back to a single fixed pane.
Old March 2nd, 2016, 09:49 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Metal framed, fixed glass windows are available for the SW models.
They'd be nice in colder climates where the windows would rarely be opened anyway.
Old March 2nd, 2016, 09:51 PM
defender1844
Amit Likhyani
hopefully D90tops will chime in. I believe I asked if it was an option and I am pretty sure he indicated that the diagonal roll cage bar made sliding glass impossible and it's no longer listed as an option.
Old March 2nd, 2016, 09:57 PM
D90Overkill
David Frank
1995 ST #2615
Good point! I hadn't thought about that. ;-(
Old March 3rd, 2016, 01:21 AM
Crash303's Avatar
Crash303
Josh Harris
97/ D90 ST #1190
I have a D90tops fiberglass top and yes the padding on the diagonal support interferes with the sliding window frame. You could cut the padding or do what I did and make custom offset diagonal supports that would allow the window frame to clear. As for the windows I drilled holes in 1" by 1/8 thick aluminum strips and put them on the inside to sandwiched the window frame to the fiberglass using button head screws and nyloc nuts. I can't remember if I had a gasket or if I used some black silicone caulking.
When the F*%# did we get Ice cream!!!
"They are, in factory original condition, noisy, they leak water in from the top and oil out from underneath, you can never demist the windows in winter, they handle like scaffolding towers, and use more fuel than Beijing." Richard Hammond
Old March 3rd, 2016, 07:40 AM
rovertrader's Avatar
rovertrader
Dale
Put them in my Tithonus, used #8 carriage bolts with washers on the inside. There is some interference from the cage which dictated mounting them opposite side. And location was dictated by getting rid of factory holes in the top.
ID:	144064   Click image for larger version
Old March 3rd, 2016, 11:25 AM
dlee888
Davie Lee
1997 D90 Soft Top
Thanks for all the input gang... appreciate it!
fiber, fiberglass, glass, hardtop, nas, top, window, windows
FS: NAS 110 rear sliding windows Roadsiderob For Sale - Parts 0 October 15th, 2014 03:59 PM
Factory New SW sliding side windows dave_lucas For Sale - Parts 7 October 6th, 2009 07:45 PM
Removing S/T Front Sliding windows Frankie Carbone Misc. Chit-Chat 3 July 28th, 2008 10:28 AM
Removing Defender Sliding Windows rjred1 Defender Technical Discussions 7 May 23rd, 2007 10:55 PM
Rear sliding windows? dmarchand Defender Technical Discussions 11 January 24th, 2006 01:37 PM
