Sleeving Track rod - Defender Source
Old November 2nd, 2015, 08:47 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Sleeving Track rod
As I put my front axle together, I want to sleeve/weld a thicker tub on top of the original to increase its strength, I've seen way too many track rods look like spaghetti after a mild hit on a rock.
That being said, Im measuring the OD of my stock track rod at 7/8". Hard to find any pipe or tube with that ID. I could go 1" but I feel that may have too much space. 3/4" will be too tight.
Anyone do this any remember what size pipe they used for a tight fit?
Old November 2nd, 2015, 08:59 AM
I used 1". Works fine. Added a 1" nut as well.
Old November 2nd, 2015, 09:15 AM
bossman429's Avatar
bossman429
Adrian
1988 90
OK - Im thinking just a few holes along the length and fill them with weld, along with welding the ends?
Also - any reason no to replace those clamps with jam nuts on each TRE? Easier to access for adjusting, and doesn't scratch up the finish of the rod.
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
You should either sleeve both or buy HD rods. A bent drag link isn't much fun either
Old November 2nd, 2015, 09:18 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
https://www.onlinemetals.com/merchan...=283&top_cat=0
Or just buy some Rover thread tube adapters from Summit Machine and make some new rods from DOM.
Old November 2nd, 2015, 09:29 AM
Originally Posted by bossman429 View Post
OK - Im thinking just a few holes along the length and fill them with weld, along with welding the ends? Also - any reason no to replace those clamps with jam nuts on each TRE? Easier to access for adjusting, and doesn't scratch up the finish of the rod.
I guess but if you buy the fancy nuts you might as well just buy HD rods. The point of sleeving with pipe is it costs $5. Pipe and weld the ends. $10 for both and it will be fine.
Old November 2nd, 2015, 09:34 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Fancy nuts? $20 total?
------ Follow up post added November 2nd, 2015 09:35 AM ------
Originally Posted by fishEH View Post
https://www.onlinemetals.com/merchan...=283&top_cat=0 Or just buy some Rover thread tube adapters from Summit Machine and make some new rods from DOM.
Did you see the price of that tube? Holy hell is it made from gold?
Good idea iWork the tube adapters. May look at that
------ Follow up post added November 2nd, 2015 09:40 AM ------
TRE THREAD is 11/16 16 right?
Old November 2nd, 2015, 09:50 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Come to think of it. I'll use the clamps and just cut the sleeve an inch or two short, so the stock clamps for over the tube. He ends will have the TRE threaded into them so they will essentially be solid and just as strong I suppose
Old November 2nd, 2015, 10:35 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Monkey wrench: Old off roading trick I read about was sleeving a square tube and welding that all up.
Old November 2nd, 2015, 10:55 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Not sure why you would use sq tubing. Round is much strong and won't have any edges to grab into obstacles if you did hit one
Old November 2nd, 2015, 11:31 AM
I sleeved my stock steering rod (well, actually galpin's stock steering rod) with 1.5" OD, 0.25" wall 4130 chromoly.
It was tig-welded onto the stock rod, leaving enough of the original rod's ends to use the stock clamps.
I think going the route with weld-in bungs is superior (the stock clamps are a pretty cheesy way of fixing the ball joints. Lock nuts would be better), but I'm not sure if there is a huge advantage strengthwise. I've used a hydraulic jack to attempt to lift up my entire truck via the chromoly steering rod, and it will bend like a noodle until it hits the nose of the diff. It returns to its original shape after being deformed, however.
Old November 2nd, 2015, 11:42 AM
LR Max
Thomason, Max
1973 Series 3 109
I've done it. Just make sure you drill a few holes in the middle of the tube and do some plug welds.
When I welded mine, it was welded at the ends and it ruined the TRE threads.
Old November 2nd, 2015, 11:51 AM
Why?
If you ruined the threads, you welded much too hot. It really does not need any welding. The pipe could just be loose. The welding is just to seal it and prevent corrosion in the gap. It is not structural. You just want a very light weld.
Old November 2nd, 2015, 12:36 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I have a tie rod from RovingTracks and like the design much better than what I did.
Pretty sure the Rover TRE's are 11/16-16 so I think the PITA is finding bungs in that thread size.
I did a search and this is the tubing I used: https://mysteelyard.com/product_info...ducts_id=11281
If I was to do mine again I would try harder to find the correct bungs and build it with 1.5" tube and that would make it easier make a clamp for the Disco pitman arm conversion (I know adding more options to the pile).
But if you got the 7/8" ID tube and sleeved the whole track rod and could find or make jam nuts that would be a nice design too. I have a 11/16-16 LH plug tap so you could make the one side.
Old November 2nd, 2015, 12:39 PM
Where can you get the nuts?
Old November 2nd, 2015, 12:43 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
looks like you can buy 11/16-16 jam nuts:
Amazon.com: Steinjäger Nuts Bulk Jam Fasteners, Bulk 11/16-16 RH 10 Pack Grade 2 Plated Zinc Yellow: Automotive
Let me know I'll go half's on a 10 pack with you
Old November 2nd, 2015, 12:46 PM
How about the required left hand thread ones?
Old November 2nd, 2015, 12:54 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Yea. Just realized I can't. Found 11/16 18.
Old November 2nd, 2015, 12:55 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
ahhhh
Old November 2nd, 2015, 12:57 PM
bossman429's Avatar
bossman429
Adrian
1988 90
looks like you can buy 11/16-16 jam nuts: Amazon.com: Steinjäger Nuts Bulk Jam Fasteners, Bulk 11/16-16 RH 10 Pack Grade 2 Plated Zinc Yellow: Automotive Let me know I'll go half's on a 10 pack with you
Ok. Not a bad idea. But will need to find 2 LH ones lol
ac, rack, vin
Heavy Duty Track Rod Kit with Tie rod ends $250.00 SafariHP The Vendors Loft 0 August 30th, 2012 04:20 PM
Harness sleeving cooked, cracked and falling aparts JFD Defender Technical Discussions 0 June 1st, 2011 06:38 PM
Equipe Panhard Rod and HD Track Rod Rugbier For Sale - Parts 14 March 23rd, 2011 09:27 PM
Sleeving Clutch Master and Slave nikojo Defender Technical Discussions 3 March 22nd, 2011 03:43 AM
Tie Rod/Track Rod joint removal....aarrrrghh DNinety Defender Technical Discussions 5 October 24th, 2010 01:08 PM
