Sleeving Track rod - Page 2 - Defender Source
Old November 2nd, 2015, 02:02 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
The Rover TRE thread nuts and bungs can be ordered from Summit Machine as a special order. They aren't ridiculously expensive, either. My total was $96 shipped for 4 bungs and 4 jam nuts.
I bought my 1.5" x .25" wall DOM from RuffStuff Specialties. I bought one 36" length(drag link) and one 48" length(track rod). The total shipped using a coupon/sale code was about $85. DOM Tube, 1.5" X .25" Wall, 1" Tube ID - RuffStuff Specialties
I added in a tube clamp from Ballistic for my steering damper for another ~$40.
So all in I have a set of steering links for about the same cost as off the shelf ones, only mine are bigger and stronger.
Old November 2nd, 2015, 02:04 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
So essentially you spent $221 instead of the $150 I would have charged you, for .3" larger rods...
Old November 2nd, 2015, 02:09 PM
Exactly. Not much point in building your own... Sleeving them with $10 worth of pipe makes sense, especially with it sitting right there. Building your own with tubing and inserts and jamb nuts makes no sense when you can just buy them and they are nicely plated.
Old November 2nd, 2015, 02:11 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
What's the O.D. and the wall thickness on your rods? What are they made from and do they include a decent and adjustable damper bracket?
Old November 2nd, 2015, 02:13 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
1.2" OD .3" wall, steel, and a bracket
Old November 2nd, 2015, 02:22 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Sounds pretty decent.
Old November 2nd, 2015, 04:19 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by bossman429 View Post
Ok. Not a bad idea. But will need to find 2 LH ones lol
I think the same supplier sells LH ones as well. Or we can make them with the tap I have.
Old November 2nd, 2015, 04:26 PM
Nope. I checked their website and they only do RH. Maybe there is a source in the UK?
I'm thinking anything soft enough to tap would not make a very good thin nut.
Old November 2nd, 2015, 04:28 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I can probably get a whole bunch of them if people need.
Old November 2nd, 2015, 10:54 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Here are the results. Pretty happy. Sleeved everything with some 1" schedule 40 black pipe. Did a plug weld every 6" 90 degree off from each other. Also welded the ends. I left 2" on each end that female threads as to not mess them up, and also leave room for the securing clamps to slide on. Figured this would be plenty strong as is bc the TRE will essentially fill that and make it solid all the way through. I did forget to get 2 nuts and have to get another one for the down tube/steering rod/ whatever you want to call the thing that's in front of the axle. Also I cut and re welded the steering dampener bracket onto the larger diameter pipe, even though I'm not sure I'm going to bother running one on this truck (we'll see).
I did make sure to turn down the heat and do the ends in stages, so the threads didn't get messed up. All turned out great.
Now to get linexed along with the pan hard bar and I'll be all set!
ID:	133746   Click image for larger version
ID:	133748   Click image for larger version
Old November 3rd, 2015, 06:55 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Originally Posted by Red90 View Post
Why?
If you ruined the threads, you welded much too hot. It really does not need any welding. The pipe could just be loose. .
that's an interesting idea- -then you could literally "roll" over those tight spots...
Rent my
Old November 3rd, 2015, 07:34 AM
that's an interesting idea- -then you could literally "roll" over those tight spots... .
Google "Dan bar Land Rover".
http://www.extreme4x4.co.uk/acatalog..._DAN_BARS.html
Old November 3rd, 2015, 12:19 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
thought that was the point of sleeving them.
Jimmy Buffett
ac, rack, vin
Heavy Duty Track Rod Kit with Tie rod ends $250.00 SafariHP The Vendors Loft 0 August 30th, 2012 04:20 PM
Harness sleeving cooked, cracked and falling aparts JFD Defender Technical Discussions 0 June 1st, 2011 06:38 PM
Equipe Panhard Rod and HD Track Rod Rugbier For Sale - Parts 14 March 23rd, 2011 09:27 PM
Sleeving Clutch Master and Slave nikojo Defender Technical Discussions 3 March 22nd, 2011 03:43 AM
Tie Rod/Track Rod joint removal....aarrrrghh DNinety Defender Technical Discussions 5 October 24th, 2010 01:08 PM
