Sleeving Clutch Master and Slave - Defender Source
Old March 21st, 2011, 11:19 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
My clutch master is taking a dump.
It's a job I would not wish on my enemies (I thought worse than heater box x2). I don't want to do it again....ever.
I've already bought a new master/slave/hose.
Anyone think there is value to sleeving the NEW units???
Will this significantly add longevity????
Old March 21st, 2011, 11:28 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I have had a number of units sleeved. Have some on hand actually. They do last a little while longer. But not indefinitely. Am having them done in a brass type alloy. Have not found anyone to do them in Stainless. If you were looking for a better mousetrap, then research putting a stainless sleeve to one. Not necessary to use the new part if you are doing this. You can send the old one as they usually refurbish as well.
Do you know a good surgeon to help with reassembly? He he he Second set of hands might help.
legend in my own mind
Old March 22nd, 2011, 03:35 AM
TS888's Avatar
TS888
Tony Sims
1984 110
I'm curious, is that because of the LHD/V8 situation? I have a RHD 300TDi, and the clutch master is easy to access.
There is a company in Virginia called White Post Restorations that sleeves brake/clutch cylinders.
http://www.whitepost.com/brake.html
Tony
1984 110 "Smokey" (sold)
Old March 22nd, 2011, 03:43 AM
Yes.
clutch, master, slave, vin
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Clutch Slave Master Fluid Mystery RickM Defender Technical Discussions 2 August 11th, 2010 06:19 PM
WTF... Fourth clutch master cylinder in 5 years ? JFD Defender Technical Discussions 6 June 23rd, 2010 09:59 AM
Clutch master and slave huck1974 Misc. Chit-Chat 7 February 2nd, 2010 10:14 AM
Clutch Master, Slave & hose sale @ BP Neil McCauley Misc. Chit-Chat 0 September 22nd, 2006 07:11 PM
