slave cylinder question - Defender Source
Old March 30th, 2012, 12:56 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
How tight is the piston inside the slave supposed to be? I pulled it out to check it and it seems really tight, like hard to push in with my finger. It takes quite a bit of pressure to get it to move then it will break free and slide in. After replacing everything the clutch was still slipping so I removed the slave and drove it with no clutch, worked fine. I am wondering if this could be the problem.
Thanks, Jason
slave
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Clutch Slave cylinder bleed?? Quimbola Defender Technical Discussions 2 February 10th, 2009 11:17 PM
What do I need to know about rebuilt cylinder heads (non-LR) loykd Defender Technical Discussions 2 October 18th, 2004 10:36 PM
