Skills needed to install AC - Defender Source
Old April 24th, 2009, 11:42 AM
aosias's Avatar
aosias
Alexandra
1995 D90
I have a used AC system that I am going to install in my 95 D90. It seems fairly simple from the research I've done. I'm not a skilled mechainc but I have some common sense. What is the skill level needed to install the system and at what point would I be best stopping to have a mechanic finish the rest? I am planning to have a shop charge the system.
Alex
Old April 24th, 2009, 11:43 AM
You should be fine. Just make sure the wiring is proper and preoperly fused and you should be ok.
Old April 24th, 2009, 11:49 AM
aosias's Avatar
aosias
Alexandra
1995 D90
All the wires I have look like they have good connections (parts and truck) so I am assuming it is just plug and play. The idea of me and soldering is frightening.
Old April 24th, 2009, 02:56 PM
I have only removed one, not installed one, but I'd rate it as pretty easy. If you truck had AC once before the wiring will be plug and play, but I'm not sure it will be if not. It's a pretty simple circuit though.
If it helps, here are a number of pictures I took when removing my AC
http://lhsw.com/gallery/AC
hth
charles
Old April 24th, 2009, 09:08 PM
aosias's Avatar
aosias
Alexandra
1995 D90
hth
charles
Your link is my inspiration that I can in fact do this myself! I don't think my truck ever had AC but I have what appear to be the AC connections in the passenger foot well.
Alex
Old April 26th, 2009, 10:41 AM
You're welcome. I took those pictures for this very reason - to help myself or whomever bought it do an install.
ac
AC install ditskovich Defender Technical Discussions 17 July 14th, 2010 05:17 PM
AC install confusion- a little help please aosias Defender Technical Discussions 6 January 3rd, 2010 05:18 PM
AC Install aosias Defender Technical Discussions 8 February 11th, 2009 02:23 PM
I'm in trouble w/ the Mrs.. pix of Full Rack install needed paulb Defender Technical Discussions 5 June 6th, 2005 09:40 PM
Bolt length needed to install Dixon Bate ronward Defender Technical Discussions 2 September 11th, 2004 06:05 PM
