Size of self tapping screws for headlight surrounds - Defender Source
Old June 13th, 2016, 05:45 PM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
Does someone know off hand what the size is for those and are they the same that is used in the interior dash? Thanks.
Old June 13th, 2016, 07:59 PM
Headlight surrounds - #8 x 3/4" (generally same as Wingtop Vents)
Interior dash has LOTS going on...which specifically are you talking about? There are some #8 x 5/8" screws (Lower Dash, Instrument Panel, Door Panels). Check strap covers are #8 x 3/4" ...Demisters I prefer to use a #8 x 3/4" actually as it fills the "hole" in the demister better, but *technically* it's a #6 x 3/4" screw if I recall.
I'll leave you with this self-serving link if you don't want to "recreate the wheel" on the interior bits & pieces:
https://www.seriesdefender.com/inter...screw-kit.html
Also have exterior kits for 110s available as well.
Old June 14th, 2016, 08:50 AM
flananuts
Matthew
Thanks Lav. I've been moving all fasteners where possible to plastic due to the never ending rusting on exterior parts unless required to be metal.
Old June 14th, 2016, 09:20 AM
I believe we need to introduce you to Black-Oxide 18-8 Stainless Steel and 316 Stainless Steel .
Old June 14th, 2016, 10:23 AM
flananuts
Matthew
Brewie built my truck so all the major fasteners are SS. Will black oxide corrode when used on powder coated steel? I do live at the beach so a lot of extra salt in the air.
Old June 14th, 2016, 11:40 AM
lav is talking about black oxide over stainless, which doesnt rust.
ht
headlight surrounds/grille NAS D-90 97Ariesblu For Sale - Parts 1 December 9th, 2009 04:57 PM
FS Td5 style headlight surrounds, used ECR For Sale - Parts 10 May 5th, 2009 12:34 PM
Grill and headlight surrounds (plastic) JBfoot For Sale - Parts 7 August 13th, 2008 04:01 PM
Headlight surrounds, like new! RoverC For Sale - Parts 7 June 24th, 2008 08:28 PM
safari Equip UK Headlight Surrounds FS SafariHP The Vendors Loft 1 May 28th, 2008 10:52 PM
