Size of fan bolts on viscous fan clutch - Defender Source
Old September 25th, 2009, 06:59 PM
imeek
Isaac
Red 94 D-90 (SOLD)
Hello All,
Does anyone know what the bolt size is on the viscous fan clutch? These are the 4 bolts that attach the fan to the clutch? The ones from my old clutch do not fit the new one. It looks like the previous owner removed the fan clutch and fan from a RCC and swamped the whole thing. I now have a new fan and fan clutch, but the bolts don't fit.
If you have a parts catalog, that would be really helpful.
Isaac
Old September 25th, 2009, 07:02 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
IICR, theres suppost to be 4 bolts, lock washers and nuts that hold that fan to the clutch. Do you have all of those?
Robert Deniro
Old September 25th, 2009, 07:45 PM
imeek
Isaac
Red 94 D-90 (SOLD)
I have washers from the old bolts. From the looks of both fan clutches, there are no nuts for either, as the bolts just go into the clutch housing.
Old September 25th, 2009, 09:35 PM
I have seen bolts or studs. Just go to Lowes/HD and try to match them up. IIRC they are M6.
Old September 26th, 2009, 03:12 PM
imeek
Isaac
Red 94 D-90 (SOLD)
Thanks Ron. Went to Lowe's and found the bolts. They were M6.
Buttoned up the truck and drove it around for about an hour. Temp gauge stops just to the very slight right of center, and doesn't move from there. Even at idle for 15 minutes and in stop and go traffic. I think the fan did the trick.
bolts, clutch, fan, fan clutch
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Latest question. Thread size on 3.9 water pump for fan clutch? Hans Misc. Chit-Chat 1 January 29th, 2005 09:03 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
