Sitting Level - OME & ARB Bull Bar w/ Warn Winch - Defender Source
Old December 13th, 2004, 12:51 PM
TurkD90
Nedim Aruz
1995 D90 SW
All,
Just got my ARB Bull bar and Warn XD9000 winch installed along with my OME springs (751 Front and 764 rear) and shocks. As far as i can tell the rear looks just about the same height as it did before. Additionally the front seems to be a tad (1") higher than i remembered. I was wondering if this is normal --- can i expect some settling from the front? Anyone else running this set up with the same issue? Can you send some pics of your rig so I can compare to mine?
p.s. i did the obivous checks and all was installed properly.
Old December 13th, 2004, 01:07 PM
Jimmys 90has those same springs, an ARD and a warn 9k lb winch. His 90 sits level.
Old December 13th, 2004, 02:07 PM
TurkD90
Nedim Aruz
1995 D90 SW
thanks for the reply -- kinda hard to tell from that angle but i don't think mine is that high in the rear. I have a SW, could that be a reason.
Old December 13th, 2004, 02:36 PM
I know not the best pic, it is just one I had laying around, I'll try and get a better one a little later. But SWs are somehow a little heavier in the rear so that could be why, I think allot of SW owners use spacers in the rear, but I thought the bumper winch combo would have offset it.
Old December 13th, 2004, 02:39 PM
TurkD90
Nedim Aruz
1995 D90 SW
thanks for all your help...hmm spacers --- what sizes do they come in and what mfr do you reccomend?
Old December 13th, 2004, 03:40 PM
You could check out
http://www.rovertym.com/
https://www.expeditionexchange.com/spacers/
or I see them on E-bay from time to time.
Old December 13th, 2004, 03:51 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Nedim, where in NY are you? I have a set of OME spacers on my Rangie that I don't need anymore. Let me know if you need them.
John C.
Old December 13th, 2004, 05:04 PM
TurkD90
Nedim Aruz
1995 D90 SW
live in NYC on 14th and B....but usually go up to my familes place in Chappaqua. What size/brand spacers do you have and how much do you want for them.
Old December 13th, 2004, 06:08 PM
JohnC
They are the OME spring spacers (I think they are 10mm in height). I got them from EE a few years ago. They are free. I just need to remove them from the RR (it's going to be donated before the end of the year). I have 4 of them. If you want them just give me a few days to remove them and we can meet up somewhere in the city.
John C.
Old December 13th, 2004, 06:30 PM
Hey John,
Nice web site. I had no idea that anybody here in the states carried all the Scorpion Off Road stuff. You should hook up with Chris Von C and come up with a special or two on this forum!!!
Old December 13th, 2004, 10:52 PM
roverboy's Avatar
roverboy
Thomas
Booger
this is gonna sound stupid. but i think you have installed the springs backwards. forget spacers...switch the fronts with the backs and i bet you anything your problem will be solved. try it...trust me.
"There is absolutely no excuse for the way I'm about to act."
Old December 13th, 2004, 11:07 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
"Sitting Level - OME & ARB Bull Bar w/ Warn Winch"
With an ARB, about 4in off the ground
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 13th, 2004, 11:41 PM
Old December 14th, 2004, 09:32 AM
TurkD90
Nedim Aruz
1995 D90 SW
Jon,
Sounds great --- I'm gonna double check this weekend that the springs were installed correctly. The shop left the tags on them so hopefully it won't be too hard to identify if they were installed backwards. If thats not the case, i can meet you anywhere in the city. I work around Union Sq. Contact me offline at nedimaruz@hotmail.com
Thanks, Nedim
Old December 14th, 2004, 04:09 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
I have the same setup and there was some leveling problem which I corrected with the EE spacers and it was a Breeze. I used 2 spacers in the rear and one in front to get a little extra lift. I can get pics if you are interested. I think it was 2 in rear and 1 in front. It was a long time ago. Haven't been under there in a while.
Old December 14th, 2004, 05:48 PM
TurkD90
Nedim Aruz
1995 D90 SW
yeah - if you have pics and it's not to much of a hassle I'd love to see them.
Old December 14th, 2004, 05:58 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
I run that setup and mine sits nice and level.
clicky for piccie
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
Old December 15th, 2004, 07:59 AM
mspell
Michael Spellman
What tires are those? They look great.
Old December 15th, 2004, 08:52 AM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
BFG MT T/As in 285/75R16.
Old December 16th, 2004, 08:07 AM
scoloco's Avatar
scoloco
'94 D90 ST
I put 751/764 into my D90. I actually remembered to measure before and after too. The front springs were the same length as the ones that came out. The rears were I think a wee bit longer.
Result after the swap: front was the same height; rear was up an inch or two. So it rides tail up unloaded, but putting stuff into the back levels it out.
I have no idea what springs came out - I assume OEM but I dont know for sure.
This is a softtop with Rockware/XD9000i up front.
HTH
winch
installing Warn XD9000i winch in ARB bumper eric_besore Defender Technical Discussions 11 March 28th, 2006 09:36 PM
New ARB Bull Bar, Hella 3000s etc sharknet For Sale - Parts 3 March 16th, 2006 08:21 AM
ARB Bull Bar W/winching capabilities? saber6 Misc. Chit-Chat 8 December 8th, 2005 06:24 PM
ARB Bull Bar for 97 D-90 Seriesman Defender Technical Discussions 4 October 4th, 2004 10:00 PM
Warn XD9000i in ARB brush bar... Trigger Defender Technical Discussions 2 June 15th, 2004 12:26 AM
