simple way to test clutch master - Defender Source
Old February 2nd, 2010, 07:58 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
What's the simplest way to test the clutch master?
I was told you can block the soft hose and if the clutch doesn't go down it's OK.
I was thinking of removing the hose on top of the master and putting a bolt in to block the flow, would that have the same effect as the blocked hose trick?
And if that didn't work I was going to try the old "Banana in the tail pipe"
Old February 2nd, 2010, 09:19 AM
I wouldn't do the bolt trick as you can mung up the mating face at the bottom of the port. If you dont have a set of pliers for clamping off lines, you can do it using a pair of vice grips with a heavy rage to pretect the line. Or if you want to be a bit less cavalier you can cut a small piece of pipe in half lengthwise and use that between the jaws and the hose.
OTOH, if the master was faulty you would probably see leakage down the inside or outside of the footwell, or you would have pedal return issues. In my experience the slave cylinder is more often the culprit.
Old February 2nd, 2010, 09:58 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Two pieces of small pipe slipped over the jaws of needle nose vice grips is the best way. In fact, it's a perfect substitute for the "official" tool. When I used to repair Series Rovers I bought 3 sets and ground off the teeth and rounded the jaws so I could clamp off all the brake lines.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
clutch, master
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
Clutch Master, Slave & hose sale @ BP Neil McCauley Misc. Chit-Chat 0 September 22nd, 2006 07:11 PM
Re-Sleeve ing Rear Brake and Clutch Master Cylinder COSteve Defender Technical Discussions 12 June 24th, 2006 12:33 AM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
» Defender Registry
LRNA04
lrna04
Lloyd
rtcgb
Add your Defender
