Simple Repairs? - Defender Source
Old December 20th, 2009, 11:33 AM
merlin8ty's Avatar
merlin8ty
Cliff Weinstein
1997 D-90 AA Yellow
Simple Repairs?
Here's the problem. I have accumulated a list of repairs that need to get done to my D90 and just curious on cost and time. Some stuff I could probably do myself, problem is I live in manhattan and not that easy to do work on a vehicle....and I just want to take it somewhere and get it all done. Snowboard season is approaching and I want to feel comfortable driving to VT every weekend. Just looking for any thoughts on total cost and time for the below items:
1. Headlight replacement. (Just the install) Still has factory headlights and driving at night is miserable. Ordered the Hella H4 with Osram Hyper bulbs. (they are sitting in my apt)
2. Oil Change - motor oil suggestions? I have read on the boards that Mobil 1 synthetic is the best?
3. Engine Light is on, has been for 2 months now. Have had no effects while driving and sometimes it's not on. I'm sure it can be alot of things
4. Odometer is scrambled some times and flickers most of the time. Still keeps accurate mileage. Would like to replace/fix to keep accurate mileage. Don't ever plan on selling but if history repeats itself (crash of 2008) i may have to rethink that. ~70,000 miles currently
5. General tune up. Looking for a good trusted mechanic to give the truck a once over.
Prior to puchasing the 90 it had a 62,500 mile service through land rover. That was in January 2009.
Again, I would like to drop the truck off and pick it up in a few days or so and have it ready for the winter travels.
ANY SUGGESTIONS OF GOOD MECHANICS CLOSE TO THE CITY WOULD BE GREAT AS WELL.
THANKS GUYS.
Old December 20th, 2009, 11:58 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Cliff lets get together between Christmas and New Years. I should be in the city. I can help you out with most of this.
You may want to change spark plugs, distributor cap, ignition wire set. We can change oil in the engine, tranny, diffs and transfercase too.
Let me know, we can get most of this done in a day.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old December 20th, 2009, 12:00 PM
merlin8ty's Avatar
merlin8ty
Cliff Weinstein
1997 D-90 AA Yellow
Sounds good. Do i need to order the stuff ahead of time?
what about engine light and odometer?
Old December 20th, 2009, 01:34 PM
floyd650's Avatar
floyd650
Alex Lapidus
1994 D90 ST #1716
If you disconnect the battery overnight the check engine light will probably go out. Alternatively, if you want to know more about why it's on in the first place, you could remove the cardboard panel in front of the passenger's feet and read the fault code on the little digital read-out. Then google the fault code and see what it corresponds to.
Old December 20th, 2009, 01:47 PM
Cliff,
Take the truck to an auto parts store and have them read the codes. The OBD2 connection is under the fuse cover on the console. It could be anything, from the gas cap not being tight to a misfire.
The 97's have coil packs, so it does not have a distributor. I believe the digital read out on the passenger side was only on the 94's. The 97's definitely do not have them.
The odometer flashing is a fairly common thing for the 97's and it really is not worth fixing. Mike at ECR used to fix them but the parts have become expensive.
If you are going to upgrade the bulbs in the headlights, you may want to put an ARB relay system in, from Expedition Exchange or make your own, because you will probably burn up the switch.
A tune up and changing all the fluids is very much recommended, use synthetic in everything. Also check to make sure that the breather tubes for the diffs are clog free. You will also want to change the fuel filter and grease the u-joints.
Doing it yourself will help you get to know your truck better, so you can fix it in an emergency. Also, download a copy of the RAVE disc, which will allow you to see the parts, schematics and diagrams of the different systems.
Old December 20th, 2009, 03:15 PM
Cliff, I can help out too ... I bought the same Hella combo and fitted them in the street ... takes about 15mins and the difference is incredible!
The bulbs are not a major wattage upgrade so should be ok on the original wiring.
For a mechanic I use Ricardo at the Foreign car centre in Queens ... he's very knowledgeable and reasonably priced. For the basic service stuff I highly recommend him.
Old December 20th, 2009, 05:14 PM
61rover's Avatar
61rover
John Crouse
Do not resist the temptation to go with higher wattage bulbs without the wiring upgrade. I knew better but couldn't resist. I was wrong.
Old December 20th, 2009, 06:30 PM
what wattage bulbs did you use?
Old December 20th, 2009, 08:39 PM
61rover's Avatar
61rover
John Crouse
I meant to say DO resist. I think they were 85w. Luckily all that fried was the socket. Could have been a lot worse. I am going to do the relay harness before going back to higher wattage. It was nice though.
Old December 23rd, 2009, 06:59 PM
rallylights.com excellent prices and 10% for mentioning the D-90.com e codes and stock wattage are plenty of light.
Soft top repairs patching an option paulb Defender Technical Discussions 7 October 13th, 2006 03:44 PM
Repairs In Phoenix Zimbo76 Defender Technical Discussions 4 October 7th, 2004 11:03 PM
Simple Dual Battery Isolator? OCD90 Defender Technical Discussions 1 April 9th, 2004 11:23 PM
BesTop Repairs? boshea Wanted 3 January 3rd, 2004 12:17 AM
BesTop Repairs? boshea Defender Technical Discussions 3 December 29th, 2003 10:22 PM
