Silly lightbulb question? - Defender Source
Old January 29th, 2008, 10:04 PM
Flagg's Avatar
Flagg
Flagg
1995 Defender 90 NAS
Hey,
I have a 1995 Soft top.
My passenger rear turn signal is out. The turn signal flashes quickly to let me know that one of the lights was out. So I figured - no problem to do this one myself! That is one thing that the Defender did right! It is super easy to get at this bulb by just taking the lense with the exposed screws.
I did so in a Sears parking lot. Took the bulb in. Grabed one that 'looked' the same. Had the guy in the Auto department look up the Defender and he confirmed the bulb. Stupidly, I threw the old bulb out on my way to the car. I Made the replacement - still no turn signal. I need to trace if power is getting to the bulb. Have not does so yet.
BUT - I had a friend that used to own a D90 tell me "that he thought the bulbs were special and could not just be bought off the shelf at Sears. Generic bulbs would not fit and I had to go thru someone like Rover's North."
IS THAT TRUE?
Flagg
Old January 29th, 2008, 10:07 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
I've bought turn signal bulbs for my 90 at auto zone before... I just looked it up in the book. It worked fine.
Old January 29th, 2008, 10:17 PM
Theres nothing special about the bulbs, but I have purchased faulty bulbs before with an internal short. Its pretty aggravating.
Old January 29th, 2008, 10:22 PM
Flagg's Avatar
Flagg
Flagg
THANKS as always for the REALLY fast answers. It was a two pack of bulbs - I will try the other bulb and then start tracing if power is getting to the light.
Thanks! Flagg
Old January 29th, 2008, 10:38 PM
hamiamham
mike
97 D-90
Try cleaning the contacts; they are probably oxidized. I had the same problem.
Old January 30th, 2008, 10:05 AM
Flagg's Avatar
Flagg
Flagg
Do I have to worry about getting shocked from the battery? Wear rubber gloves? Or do I just go in there with a pencil eraser and clean the contacts?
Sorry I am an electrical bonehead. Got to admit......electricity scares me.
Thanks......Flagg
Old January 30th, 2008, 10:27 AM
GYM's Avatar
GYM
Gary
97 SW
Originally Posted by Flagg
Do I have to worry about getting shocked from the battery? Wear rubber gloves? Or do I just go in there with a pencil eraser and clean the contacts? Thanks......Flagg
No.
No.
Yes.
add a shot of WD-40, for good measure.
Old January 30th, 2008, 09:07 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I just had this happen and was the first fix for my 90 under my ownership. Turned out the bulb socket was bad - a trip to the local LR dealer and $5 for a single prong (I think the brake lights are 2) and it was working fine. The only bummer about the whole process was that the screws for each light were stripped. I went to West Marine and got some #6 SS screws and some washers.
Old February 18th, 2008, 10:39 AM
Flagg's Avatar
Flagg
Flagg
OK - finally had a warm day.
Tried the eraser trick - contacts were dirty. Did a shot of WD40. Still no light. I ran out of time today.
Next I am going to try to trace if power is flowing up the wire to the blub socket - and then perhaps I need a new socket like Don.
Thanks for all the tips...........I will post back what it was when I find it.
Flagg
ht
Silly pronunciation question GaryBaxter Misc. Chit-Chat 10 August 13th, 2009 07:54 PM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
Dumb ignition/door key question, did search first Neo Defender Technical Discussions 15 May 30th, 2005 07:10 PM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
