Silly Girl ? about Tire Speed Rating ?? - Defender Source
Old September 24th, 2005, 07:34 PM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
02 D2, 13 E350 AMG, 11 Ford F350
I have a question about Tire Speed Rating. What is a better ratio for a Rover? 109S or say 108/104S ? I am not sure what the dash behind the 108 is for after the last example? Could someone better explain this to me? I understand for the most part that S and R stand for how fast you can go however I am still unsure of why some tires have for example the 108/104. Thanks in advance for helping me with this conundrum!
I bought the diamonds myself so I would not have to say thank you to anyone.
Old September 24th, 2005, 08:41 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
S is the speed rating for the tire. The two examples you provided are both "S" rated tires which means they are rated up to 112 mph. "109" and "108/104" probably refer to the Load Index. A tire with a load index of "109" can support 2271 lbs, "108" can support 2205 lbs and "104" can support 1984 lbs.
Old September 24th, 2005, 10:55 PM
Sometimes they give a 2 load ratings for dual wheel aplications vs singal wheel aplications. Like it is rated a 108 as a single and a 104 as a dual.
tire
Tire options after OME lift... Rover- Girl Misc. Chit-Chat 23 February 12th, 2008 05:06 PM
ST rear tire carrier / tailgate rattling... DiscoDino Defender Technical Discussions 9 December 3rd, 2005 06:50 AM
12.5" tire on a 7" rim? souza Defender Technical Discussions 16 August 19th, 2005 04:04 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
» Defender Registry
110
Mes788
Big D
rtcgb
Add your Defender
