Side Step Installation - Defender Source
Old September 14th, 2011, 04:29 PM
provfirescott
1997 D90 SofTop White (SOLD)
Just bought a set of what appear to be factory side steps for my 97 Softtop
Could some post a few pics on how the brackets are attatched please
Old September 14th, 2011, 04:39 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Here is a pic http://i63.photobucket.com/albums/h1...79C73-orig.jpg
On a serious note you just have to climb underneath the truck with them in hand and look at it. If you are buy your self use a couple boxes to assist so you dont bang them up. It is a fairly simple install.
Old September 14th, 2011, 04:46 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Awesome. I haven't decided whether or not to install mine, but these directions and hardware photos are a huge asset should I decide to. Thanks for posting.
Old September 14th, 2011, 05:23 PM
These are for an LR3. Just kidding looks like you finally bought something for the 90!
Old September 14th, 2011, 06:14 PM
provfirescott
My only concern are the little thin brackets they dont seem to be bent the correct way
Old September 14th, 2011, 06:40 PM
specops1526's Avatar
specops1526
Beluga '97 90
I say leave the sidesteps off. I had them on my truck when I got it. Was too lazy to take them off for years. Once I got them off, the truck looked so much better.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old September 14th, 2011, 06:46 PM
bjf's Avatar
bjf
barry f
94 ST #395
Years? You waited until 2009. That is more than years. Unless you are a midget like some people or in a wheel chair I say leave them off. If you are a wheel chair an engine hoist will be more appropriate.
Old September 14th, 2011, 06:57 PM
specops1526
Beluga '97 90
2009 is only 10 years since I got the thing. That's not that long...I probably only put like 2 miles on the truck in those 10 years. Can't believe I broke the vacuum sealing on the truck...totally worthless now.
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old September 14th, 2011, 08:43 PM
provfirescott
Not an option to leave off wifey is only 4'10"
Everything gets sides steps in this family
Old September 14th, 2011, 10:27 PM
tjfslaughter
thomas
Burbon
good. Put the side steps and do a 2" lift.
If I was closer I would help with the install I got a set from Rovahfarm last year at my lovely wifes request.
First complaint was that heels still fall through them.....
Old September 15th, 2011, 01:33 AM
specops1526
Beluga '97 90
If you have to put them on, don't sweat the install. From my removal, it only looks like there are a few bolts and it looks straight forward. Most of the bolts are smaller sizes. There is only one large bolt at the front. I think it's a 19mm or something like that. Just make sure you get some milk crates from the local grocery store to set them on as you install so you aren't trying to hold them up while you tighten the bolts.
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old September 15th, 2011, 12:53 PM
provfirescott
Pretty easy install except the two large bolts in the front that hold bod to frame didnt have nuts on the must have backed out and fallen off over the years
Old September 13th, 2016, 05:16 PM
chi97d90le
David Near
1997 NAS Defender 90 LE
May I ask where you sourced these? Thanks
installation
Side step install - do it look correct? paulb Defender Technical Discussions 10 January 25th, 2008 02:53 PM
Side Step question 48vphantom Defender Technical Discussions 10 January 17th, 2007 09:17 PM
NEED side step Campbell Wanted 3 December 2nd, 2004 08:42 PM
WTB: Driver's Side Side Step dzientek Wanted 0 November 8th, 2004 12:21 PM
Wanted: D-90 seat back trim cover/ driver's side side step dzientek Wanted 2 August 23rd, 2004 06:39 PM
