Side sill guard install ? - Defender Source
Old September 22nd, 2008, 11:59 AM
durangorover
Chris Wherry
1995 D-90
This may seem like a stupid question, but what is the best way to install sill guards. Do they bolt right over the factory sills? Wouldn't the vibration from the vehicle cause the two to rub together destroying the factory painted sills? There were no mounting instructions or hardware that came with the AB package. Thanks, Chris
Old September 22nd, 2008, 12:43 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
With the Safari Guard rock sliders that I have the factory sill piece below the door comes off. It is just a couple small bolts. Then the sliders bolt/weld on.
Old September 22nd, 2008, 01:15 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
If you mean the 5 bar protection plates, then I have always installed mine with rivets and some silicone on the backside of the panel. I run a bead all the way around, around the rivet holes, and then make a squiggly pattern in the middle. This eliminates moisture and vibration.
Old September 22nd, 2008, 04:03 PM
durangorover
Chris Wherry
1995 D-90
Yes I'm talking about the 5 protection plate. I don't have a riveter, would you use some SS bolts instead? There are only four holes between the top and bottom you'd have to drill thru the factory sill to secure. It doesn't seem like that would secure it very well though.
Old September 22nd, 2008, 04:35 PM
you have to drill holes in the flimsy factory sills. The five bar protectors don't add much protection, they cover up previous damage well.
Old September 22nd, 2008, 07:05 PM
OEM ones are always require drilling holes, so the sill damage thing is a bit moot since you're destroying the sill to install the plate.
What color is your truck? If its yellow, I'd happily trade you drilled sills for undrilled ones. I have the black chequer plate on mine that I'd like to get rid of.
Mantec Sill Protectors and LR Side Steps Arnzo Defender Technical Discussions 3 September 10th, 2009 11:16 AM
Rovers North Tail Lamp Guard Install Arnzo Defender Technical Discussions 13 September 6th, 2008 07:17 AM
Side step install - do it look correct? paulb Defender Technical Discussions 10 January 25th, 2008 02:53 PM
Rear Bumper, Side Steps and Sill Guards from a '97 LE AggieD90 For Sale - Parts 5 December 30th, 2005 10:37 AM
Alpine White Side Sill roverboy For Sale - Parts 0 November 8th, 2005 03:53 AM
