Side Repeater - Defender Source
Old January 13th, 2012, 09:35 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
Side Repeater
Has anyone upgraded to the late model side repeater? My current side repeaters have two sharp pointing male stems the are forcefully pushed into place. I would like to upgrade to the '03 or newer clear lens. Any idea how these mount? Also, do i have a cut a larger hole?
Thanks for your help.
Old January 16th, 2012, 12:23 AM
Matt:
Noticed no one has replied. I have the newer style repeaters on my truck...BUT I didn't put them on, it came that way. I'd be happy to dig into it and get you some detailed pics later this week when I'm back at the truck if you think it will help you - just let me know.
For what it's worth I highly recommend them, it looks ten times better and more modern than the old block style repeaters.
Old January 16th, 2012, 12:44 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
These guys have tons. Int'l shipping available.
Paddock Spares and Accessories has a wide assortment of items. I linked the repeaters page below.
http://www.paddockspares.com/589143r....html?___SID=U
Old January 16th, 2012, 07:34 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You should be able to find a clear lens to replace yours with out modification. The newer style will need some body panel modification.
Land Rover 110
Old January 16th, 2012, 01:02 PM
PaulMc's Avatar
PaulMc
Paul McConnell
1989 110 2.5 Turbo-Diesel
They can be made to fit easy enough.
You have to enlarge the hole in the wing (fender) to the correct size and shape - find someone with a Discovery II or Freelander 1 and (with their permission ) pop-out their side repeaters and take a rubbing to make a cutting template.
The connectors aren't the same as the old type, the newer side repeaters use 2-way AMP/Tyco Sealed MQS Connectors.
Have a look at this thread on LR4x4 -
http://forums.lr4x4.com/index.php?sh...dpost&p=605984
As I posted in the LR4x4 thread, I can supply suitable MQS connectors but, since posting that on LR4x4, I've had to increase my price to 3.95 each (+ Postage)
Paul.
Paul.
1989 Arles Blue 2.5TD 110 Hardtop
1999 Epsom Green Discovery II 4.0 V8i 'XS'
Old January 17th, 2012, 07:24 PM
Rosproline157
Matt Oaks
1992 Defender 90
Matt:
Jason, Thanks for the offer! Assuming Paul's link is correct, it looks like those lights just snap into place. If thats correct, don't spend the time taking pictures. I really appriciate the offer.
I just need to open up the holes a little, I'm in. Their is no doubt they look better.
need Discovery II side repeater Harness Plug FlaD90 Defender Technical Discussions 2 September 16th, 2009 01:12 PM
Side Step question 48vphantom Defender Technical Discussions 10 January 17th, 2007 09:17 PM
WTB: Driver's Side Side Step dzientek Wanted 0 November 8th, 2004 12:21 PM
Wanted: D-90 seat back trim cover/ driver's side side step dzientek Wanted 2 August 23rd, 2004 06:39 PM
Side Brackets for Rear Bench Seat & Rear Seat Belts zed111 Defender Technical Discussions 2 August 13th, 2004 05:33 PM
