Side Marker Bulb Replacement - Defender Source
Old December 22nd, 2004, 06:57 PM
Matt Klapmust's Avatar
Matt Klapmust
Matthew Klapmust
'94 D90 ST
Trying to replace the side marker bulbs and ran into a little trouble. Once both screws are out, the marker does not seem to budge (not sure the last time these bulbs were replaced). My guess is the old rubber gasket between the lens and the panel is sticking, or is if there is something else to detach? Any help would be appreciated.
Old December 22nd, 2004, 07:25 PM
Leave it in place, order new lenses (10 buks each at RDS) and then pop them off. Mine cracked in half when they popped free. Once the screws are out, its just grime holding it in place.
Old December 22nd, 2004, 09:25 PM
Matt Klapmust
Matthew Klapmust
'94 D90 ST
Any body damage? Mine seem to be flexing the panel quite a bit when I pull on it.
Old December 22nd, 2004, 09:56 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Matt,
The 1994 and 1995 side marker lights are different. I have a spare set from my 1994 if you break any. I replaced mine with a set of LED side marker lights...they are actually for a transit bus but are an exact match for the 1994 style lights. I will see if I can locate the catalog that I ordered them out of.
Rob
Old December 23rd, 2004, 04:26 AM
Mark M
Mark Mathews
'94 Beluga Black ST
If you are just trying to replace dead bulbs they just twist out from the back of the lens. You might want to have a fine file handy. When I went to replace a dead bulb it turned out the problem was the connector was corroded.
Old December 23rd, 2004, 01:23 PM
Wolfeie
Townsend Wolfe
'94 D90
To clarify a bit from Marks post. No need to remove the screws. Reach behind the body panel to where the wires enter the lense from the back. Twist the plastic part where the wires enter about 1/4 turn and then you have access to the bulb.
Old December 23rd, 2004, 04:02 PM
Matt Klapmust
Matthew Klapmust
'94 D90 ST
Thanks all, for the input, I will try twisting them out once it stops friggin raining here!
Old December 23rd, 2004, 04:28 PM
bugula
Keith DuFresne
'94 AA Yellow 90
heh, this rain sucks. still have shopping to do but i've heard that 66 and the toll road are in sorry shape because of accidents.
Old December 23rd, 2004, 06:09 PM
Mark M
Mark Mathews
'94 Beluga Black ST
Sorry my post wasn't more clear. I guess that is what happens after a night out at the casinos and bars!
ac
Side Marker Light - 110 bjf Wanted 7 December 29th, 2009 01:50 AM
Need mini dash bulb light replacement Doug Young Defender Technical Discussions 8 January 27th, 2005 07:02 PM
Instrument light bulb / Sylvania replacement Mark M Defender Technical Discussions 2 November 17th, 2004 04:23 PM
Side lamp bulb holder Neo Defender Technical Discussions 5 January 30th, 2004 05:07 PM
