Side lights fuse blowing - Defender Source
Old May 4th, 2008, 04:51 PM
owen's Avatar
owen
Owen Jones
Yellow`95 D90 ST #2188
What is the best prcess for tracking down a short in my drivers side/instrument light circuit?
The problem started right after I added a center switch console for lockers, compressor and Hellas. The swiches are iluminated through the instrument circuit which is part of the drivers side light circuit. I discoonectd the center console instrument lights but the fuse still blows (???).
Around the same time I also replaced the front and rear marker lights.
At first the fuse would take an hour to blow but now it pops right away with a heavy short.
All other circuits are working, including the center console.
Any guidance before plunging in would be a great help!
Thanks in advance
Owen
"I think you need a little weatherstripping - right here..."
Old May 5th, 2008, 06:16 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
My guess would be that either you pulled a wire a little and it is shorting on something after your install or, if you were messing with the markers, check those out b/c they wiring and bulb sockets both corrode pretty badly and might be shorting out.
Old May 5th, 2008, 10:59 AM
GYM's Avatar
GYM
Gary
97 SW
Might check your license plate light bulbs, too. They are on that same circuit...
ht, lights, wing
Side and Running Lights Question ronward Defender Technical Discussions 3 July 24th, 2006 06:57 AM
electrical short right side lights thewap Defender Technical Discussions 5 June 15th, 2006 12:31 PM
Repeatedly blowing undehood 30A fuse Hans Defender Technical Discussions 1 September 6th, 2005 04:24 PM
Blowing wiper/speedo fuse like crazy....help! P1CR Defender Technical Discussions 4 March 11th, 2004 03:23 PM
