side fitting snorkel on NAS - Defender Source
Old September 15th, 2006, 12:30 PM
Has anyone tried to mount a side fitting snorkel (mantex style) on an NAS Defender wing? I'm trying to figure out if it's as simple as cutting a hole, or if the non-NAS recessed vent area is critical to fitting. I would prefer to not go with the wingtop NAS style if I can avoid it. How about the straight down the wintop universal fit type?
Old September 15th, 2006, 12:52 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I'm pretty sure the passenger side euro style one does not fit, the heater is in the way.... don;t know about the drivers side but look out for clearence fro the master cylinder and steering line. Try to envision the tube as well... whats so bad about the wing top version?
Old September 15th, 2006, 12:54 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
You mean like the southdown method?
Old September 15th, 2006, 03:35 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I think he is referring to the Diesel version with the side (vertical) mounted snorkel. I looked at doing it at one time but had trouble with the master cylinder location--it is possible, however, but it would take a bit of creative routing that, in my opinion, would make it not worth it. I was going to get the wing mounted air cleaner to run it through and then directly into the MAF, but it just was not smooth and there was no access due to the brake MC. My other concern was that here in Colorado, I have a hard enough time keeping my mirrors from breaking in the forests and did not want to have to worry about the side mounting of the snorkel.
Old September 15th, 2006, 03:49 PM
i would think for the side mounted ones, that they would have to work with the brake booster in place. As for the southdown, that is the other straight down version I was referring to. Mantec has one like that, as in the picture I have attached. I'll have to check out the southdown. can you tell me more about that one? how is it routed? close up pics?
Old September 15th, 2006, 07:08 PM
roverboy's Avatar
roverboy
Thomas
Booger
Is this what you're referring to?
"There is absolutely no excuse for the way I'm about to act."
Old September 15th, 2006, 08:37 PM
Thomas, that is what I'm referring to. Did you mount that to an NAS wing with no side intake, or did it have the original recessed hole for the side intake?
Old September 15th, 2006, 08:53 PM
roverboy's Avatar
roverboy
Thomas
Booger
It's a diesel, and it's the euro body panel with the recess for the intake. I'm not sure what you'd run into trying to route it through the fender with a NAS V8, but if you can make it work, I think you'll be happier with a whole new fender set up.
Old September 15th, 2006, 09:12 PM
I would be interested in the 200 tdi version that comes in from the drivers side fender, and I'm having a 2.8 PS diesel put in mine. I just want to know if it would flush mount or not with the recess.
Old September 16th, 2006, 01:27 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
The Mantec 300 Tdi rasised intake (out the fender) will not work with the NAS cage as it is made to be bolted to the windscreen frame, not the roll cage tube, so you have to modify the outlet to change the angle a little. A little fabrciation and you are all set.
Email:
nas, snorkel
Mantec snorkel through wing on a NAS truck? dmarchand Misc. Chit-Chat 22 January 16th, 2009 04:11 PM
NAS 110 Passenger side side step needed SOUTHPAW26 Wanted 4 June 14th, 2008 12:15 PM
NAS drivers side fender steved90 Wanted 0 August 1st, 2005 04:52 PM
Safari Snorkel on NAS Defender BradforD90 Misc. Chit-Chat 7 September 29th, 2004 12:03 PM
FS: NAS Fiberglass Top, NYC area NASD90 For Sale - Parts 1 September 1st, 2004 05:17 PM
