Side marker lights and front running lights do not illuminate with the first click of the switch in my 110. Turn signals work, headlights HI and LO work, hazards flash. Just the front running and side markers are inop in the first position of the switch. I haven't started on it, but would this be fuse related since the lights do burn with the turn signal switch and the hazard switch. Need a place to start! Thanks!
Hi, I would start by checking the fuses. If you look at the schematics in your manual, the side lights are seperate
right from left. The running lights are also seperate. My first guess would be the light swithch itself?
Those switches are always suspect Ron, but it's usually the headlights that go. I'd check the fuses, then pull the plastic off the steering wheel and pull out the ol' test light. You should be able to tell if there's power to the lights after the first click of the switch.
1984 One Ten, very few fuses... I'll check them, and the switch. Thanks guys!
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
