Sick Of Messy Oil Change - Defender Source
Old October 6th, 2004, 02:00 PM
Does anybody out there have a tip on how to change the oil without making a huge mess in my garage?
Has anybody tried the "suck out the dip stick" method?
Sucker Method
Thanks!
Old October 6th, 2004, 02:39 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
What are you doing that is making it such a messy job? I can change mine without a drop on the floor but I always get a bit on my hands, rubber gloves solve that problem. You can replace the drain plug with a drain valve that has been discussed here or on the Discoweb at length. I would be hesitant to do the Sucker method. I like flushing my crankcase with some cheap oil after it has drained to flush out any bits that may be in there and I doubt you would get that with the sucker method.
Old October 6th, 2004, 03:00 PM
http://www.defendersource.com/forum/...ead.php?t=2548
http://www.defendersource.com/forum/...ead.php?t=1305
Old October 6th, 2004, 03:18 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Put a large plastic bag round the oil filter once it's cracked loose, that cuts down on spilage too.
Mike Hammond
Old October 6th, 2004, 03:35 PM
artm
Arthur Maravelis
97 SW
Cardboard under pan and filter - mandatory!
A large 10 qt or so plastic oil tub from Walmart. The kind with a small hole on the top, middle. When the oil plug is about to fall off put a funnel under it to catch it and control the oil flowing out.
You can do the plastic bag over the filter or punch a nail hole in it and drain it.
I don't trust those valves. If one fails it's trouble.
Old October 6th, 2004, 04:37 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
It get's better with each change. First one was a disaster. Second one hardly a drop as I knew where to position the pan and knew to adjust it to the oil draining.
I would agree with Art.
EwS
Old October 7th, 2004, 09:54 AM
mspell
Michael Spellman
I wedge a piece of cardboard between the header & the oil pan, so the oil gushes out & flows down into the pan. I actually use one of the top flaps from the cardboard case of oil I buy for the oil change. Someone here gave me the idea, but they use(& re-use) a piece of aluminum. The other thing I have is a magnetic probe, I let the drain plug pop off & fall into the pan, then fish it out with the probe.I was going to say that the filter sucks, but using a bag around it is a great idea. Thanks artm!
Old October 7th, 2004, 10:32 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Didn't Jiffy Lube used to have those drain plugs for some system they could attach a hose to the plug, kinda vacuum the oil out through the drain plug.
I wonder how that worked and if it can be done in a home shop.
I like the bag around the filter idea, must try that next time.
-Hans
My oil line fix
My 100k stopped odometer fix
Old October 8th, 2004, 03:00 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
I like the 'plastic bag around the filter' idea, guys, thanks!
I usually get the oil out without too much spilling, and then end up accidentally knocking the pan with my foot and sending some oil flying. Murphy never fails.
Old October 8th, 2004, 10:00 AM
artm
Arthur Maravelis
97 SW
I must say I don't like the plastic bag idea. You're contaminating a piece of plastic with oil and introducing this to the environment - probably throwing it away with the trash.
I would rather spike a hole in the filter or drain it directly into the pan. To be honest, once you move that big drain pan under the filter area it will catch it all and only lightly smear your hands. No big deal.
Yes, I am an Enviro-Nazi.
Old October 8th, 2004, 11:10 AM
haha driving a D-90. I try to be eco friendly but I mean o well as much as those things leak drips drops etc. I need an oil well but with that being said go ride a bike. <-- my main mode of transportation
good point tho Arthur it is good to see the used oil off to the right place all of this shit adds up if you think you can just "throw it away"
Old October 8th, 2004, 03:01 PM
mikeslandrover
Mike Hammond
and what happens to all the oil spilt on the drive????
At least if the spill is contained in the bag and you've got the choice of what to do with it
Diesels have some nasty stuff in their used sump oil and it's best that it doesn't come into contact with your skin
I usually put an 8' x 4' sheet of hard board under the Landrover. I can then slide out the way really quickly when the oilchange starts to go horribly wrong
Spills are easier to wipe up too
Mike Hammond
Old October 8th, 2004, 03:15 PM
artm
Arthur Maravelis
97 SW
"All the oil spilt on the drive" ? What do you mean? I said move the drain pan to under the filter. No oil on drive.
You're right about protecting your skin - even from non-diesel used oil. But we're all lazy to some degree.
Old October 9th, 2004, 01:52 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
'doesn't make sense to me. With the "hole in filter" method, you're still "contaminating" things with oil; hand or glove, and the nail. 'not any different than the small residue that's left in the bag after you've drained/wiped most of it from bag into oil pan.
In any case, it seems negligible to the oil residue remaining in the filter itself, which is also going to get put in the trash.
And to me, getting worked up about this little amount is more ideological than science-based. Properly disposed of, this little bit of rotted dinosaur isn't going to lead to groundwater or soil contamination, the two big worries with oil contamination (at least not with my trash: I know where it goes).
Old October 9th, 2004, 11:05 AM
mikeslandrover
Mike Hammond
With a Tdi the front prop is in the way, oil pours all over the prop before getting into the carefully placed bucket (if you're lucky).
Mike Hammond
Old October 9th, 2004, 02:33 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I pull the truck in the backyard. Dig a hole. Drive the truck over the hole. Drain oil into hole. Back truck up cover hole. No messy driveway.
Old October 10th, 2004, 01:43 PM
mikeslandrover
Mike Hammond
Even better - use someone else's back yard
Mike Hammond
Old October 12th, 2004, 09:28 PM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
The cut plastic milk jug sounds like the easiest-to-implement solution. The bent aluminum is slick. But that Difflock.com drain plug is definitely the sweetest solution of the bunch.
Thanks for the ideas on how to keep the oil from spilling all over the drive way.
oil change/oil cooler line change sirjond Defender Technical Discussions 12 January 25th, 2013 03:01 PM
Oil Change gtg067i Defender Technical Discussions 31 July 13th, 2005 10:24 AM
Oil Change Screw-up zed111 Defender Technical Discussions 9 July 19th, 2004 11:48 PM
