Shuddering when shifting... - Defender Source
Old August 25th, 2004, 06:41 PM
mlw911
Michael Walter
1995 D90 ST
When I shift, especially coming out of 2nd, I get a shuddering in the clutch/tranny like I am not giving it enough gas, though I am giving it plenty. My clutch pedal has alot of play and seems to release only after letting up on it quite a bit. Any thoughts? I am wondering if there is something on the clutch plate causing this.
Thanks-Michael
Old August 26th, 2004, 09:18 AM
Sounds like maybe the clutch is not disengaging all the way? Is there plenty of fluid in the system? I would just make sure that everything thatís cheaper to fix then the clutch itself is working properly first.
Difficulty shifting gears martym Defender Technical Discussions 3 November 4th, 2006 04:38 PM
97 D-90 Auto Transmission Shifting at Higher RPM parkcity4x4classic Defender Technical Discussions 7 October 30th, 2006 05:35 PM
Problems shifting out of 1st when cold chalkcreek Defender Technical Discussions 2 July 14th, 2006 10:56 PM
94 shifting problems jstrong98 Defender Technical Discussions 6 January 26th, 2006 03:06 PM
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
