Shudder in clutch when reversing - Defender Source
Old April 12th, 2014, 04:57 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
This just started in my 94 defender, when reverse is engaged and I let out the clutch there's a shudder like the clutch is slipping. It also happens when slowly engaging 1st on steep hill.
Old April 12th, 2014, 05:04 PM
bjf's Avatar
bjf
barry f
94 ST #395
Sounds like your clutch is going. Mine did that before I replaced it.
Old April 12th, 2014, 05:10 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Lots of clutches do this--i believe it is caused by a slight warp in the clutch plate. Mine does this--but I know I have plenty of life left.
Old April 12th, 2014, 05:17 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
I replaced the clutch 15k ago, but half those miles are off-road. I must be harder on it than I thought. Fluid levels are fine, but do have a very mild oil leak from what looks like oil pan.
Old April 12th, 2014, 05:37 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
did you cut the flywheel when you did it ?
No Mall crawler here
Old April 12th, 2014, 05:57 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
No, is that causing the problem ?
Old April 12th, 2014, 06:01 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
I always true the flywheel so the new clutch beds in correctly ....you might get away with cutting flywheel and scuffing the clutch but I wouldn't recommend it . Have to take it apart and inspect the disc
Old April 12th, 2014, 06:37 PM
Does the clutch engage at the end of its travel?
Old April 12th, 2014, 09:11 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
Yes, doesn't seem to be a problem once engaged.
Old April 12th, 2014, 09:17 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
The shuttering is due to the disc engaging on a uneven surface
Old April 12th, 2014, 11:46 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
What's the best fix.
Old April 13th, 2014, 01:17 AM
Since it's engaging/disengaging at the end of the travel, the clutch needs replacing.
Old April 15th, 2014, 12:21 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Have you driven in any deep water lately? Mine used to do this if I got it wet... Would go away after a bit and dried out.
Oil leak could potentially have the same effect if it's getting on the flywheel surface. Only way that would happen would be from a rear main seal. If it's the oil pan that's leaking I don't see how that oil could get up into the bell housing.
Old April 15th, 2014, 01:38 PM
Is the wading plug removed? Do you have a leak at the back of the oil pan?
Old April 15th, 2014, 02:04 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
No wading plug, the leak from the oil pan is in the back of the pan.
Land Rover Defender clear reversing light/lamp reverse Ben01 For Sale - Parts 3 February 3rd, 2014 04:09 PM
Engage clutch - shudder and clunk Ghale Defender Technical Discussions 4 August 16th, 2013 04:16 PM
Shudder from a stop bossman429 Defender Technical Discussions 8 October 6th, 2012 12:31 AM
clutch shudder isleofman Defender Technical Discussions 1 February 4th, 2010 10:02 PM
front end shudder after increasing lift from 2" to 3-4" rgrrvr Defender Technical Discussions 0 January 19th, 2008 08:35 PM
