Show me your rear ends! - Page 2 - Defender Source
Old November 3rd, 2006, 03:22 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Rear quarter flimsy IMO. The bumperettes give protection in case of rock contact at angles off roading. Good place to hi-lift if sills are not accessible in tight spots, and OK for light recovery.
Old November 3rd, 2006, 03:45 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
My SG ends have saved the rear quarters a few times. If you look closely at the picture Cube II posted of my baby's rear end, you will notice the missing power coat, a result of setting it down on a rock and sliding off.. It is the main reason why I bought them. They also seem sturdy enough to hi-lift from, and they through bolt with the rear cage support, but I haven't tried to use the highlift on them yet..
~Scott T.
'95 D-90 ST - AA Yellow
Old November 3rd, 2006, 06:27 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Whats the URL for the Scorpions website?
Old November 3rd, 2006, 08:47 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
4x4 adventure gear sells them.
http://www.4x4ag.com
Old November 3rd, 2006, 09:50 PM
will they work with a mantec tire carrier?
Old November 3rd, 2006, 10:22 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Originally Posted by Cube II
Something better than this
Here you go, SG Bumper Corner photos..
Name:	SG Corner 1.jpg
ID:	7308   Click image for larger version
Name:	SG Corner 2.jpg
Name:	SG Corner 3.jpg
ID:	7310   Click image for larger version
Name:	SG Corner 4.jpg
Name:	SG Corner 5.jpg
ID:	7314   Click image for larger version
Name:	SG Corner 6.jpg
~Scott T.
Old November 4th, 2006, 08:13 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Thanks you too Scott for the pics.
combined with a small "return" under the rear quarter (...)they might protect the quarter from coming in contact with a rock/tree....... Or maybe you get hung up on the thing you added. ...
Hey John,
that's why I'd like to keep them as minimal as possible.
Other than the vulnerable rear quarter they should save the lights working as "spacers" when reversing...
...sort of a "non electronic" parking sensors!
Recently I bent my RHS quarter and that hard-to-find NATO light reversing...reversing into another D90 door!!!
Although the added alu sheet I made as second skin, the panel bent easily.
Other Defenders apart,trees are the main menaces.
I think a couple of these,protruding as much as necessary to keep the lights out of the way could help sliding on unmoveable objects...
I may consider to cut the lower portion of the corners so to gain a bit of clearance.
Scott,do the SG protectors require body trimming?
As the Boulder Bashers type?
(in the vendors section)
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old November 4th, 2006, 10:56 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Hey Michele,
The SG corners DO NOT require any body trimming. For this reason they are not as minimalistic as they could be, but I didn't want to get into hacking up my 90. Some are okay with this, I just am not.
~Scott T.
Old November 4th, 2006, 12:06 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Looks like someone could have used some rear corners recently...
Old November 4th, 2006, 12:47 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Post
Ok ok,that's fine,I too was (and partially am still) reluctant to cut when I can avoid,
I was sure I heard some cutting was required but it's obviously false.
Just to know,I'll see what to do,my clever "oh-so-easy" projects usually drag on for months and months before seeing the light...
Sometimes I'd just like a big shopping cart...
Michele
D90 VNTdi
[O]===[O]
rear end
WTB Rear bumper ends cgalpin Wanted 9 April 30th, 2009 11:43 AM
Rear bumper ends.... with stock bumper CDN38 Wanted 8 January 16th, 2007 07:35 PM
2 female ends for rear seatbelts in softop draaronr Wanted 4 May 5th, 2006 01:20 PM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
