Should there be wires going to this? - Defender Source
Old March 8th, 2012, 01:48 PM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
Putting back together after overhaul. Looks like it's a coolant temp sensor, but the temp gauge in the dash works fine.
it's a 94 without A/C
Old March 8th, 2012, 02:33 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
My '94 (no A/C) looks the same. No wires.
Don't know what it is though.
Old March 8th, 2012, 02:58 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
On the rangerover classic EFI engine (3.9) this is used for the 14CUX ECU temp sensor (for the ECU, not for the dash guage)
With it disconected I can't remember if the engine runs rich (as in, ECU thinks the engine is cold so gives a "choke", excess fuel mix) or runs at "normal" temparature mix.
Old March 8th, 2012, 03:01 PM
I see three sender blades. a double and a single. If I recall, you have 3 devices needing signal: a warning light, dash gauge, and ECU.
Old March 8th, 2012, 03:08 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
That is actually used on the RRC to activate the two electric fans in front of the radiator that come on when the ac is used. No ac= no wires needed.
Daniel
Old March 8th, 2012, 03:16 PM
Yes, same for a 94 without A/C
Originally Posted by pendy
I'm here for the D's
Old March 8th, 2012, 03:57 PM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
Great, I feel better now! Thanks for the replies.
Spark Plug/ ignition wires mdmccallum Defender Technical Discussions 3 September 1st, 2005 11:48 AM
Magnecor plug wires jabber Defender Technical Discussions 4 June 26th, 2005 02:07 PM
Red Magnecor 8.5 wires for 97 D90 Davis For Sale - Parts 3 April 10th, 2005 02:19 PM
hiding the overhead ralleye lamp wires GeoParth Defender Technical Discussions 1 March 29th, 2004 04:03 PM
Best Ignition Wires? wicks Defender Technical Discussions 7 February 22nd, 2004 10:10 PM
