Should there be a plug here? - Defender Source
Old July 2nd, 2012, 11:12 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Was looking underneath and noticed there appears to be a bolt or plug missing here. I'm worried that this shouldn't be. Thanks in advance!
Old July 2nd, 2012, 11:33 PM
That's the wading plug I believe...technically you should plug it before heading to the water to play around.
Old July 3rd, 2012, 12:01 AM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Thanks! Do you know a part #? Is it a common bolt that I could pick up?
Could be a useful thing going to the pine barrens ;-)
Old July 3rd, 2012, 05:24 AM
maleger
Marc-Andre Leger
Wading plug
Could I put a breather there instead of a plug ?
If so, does anyone know what is the tread size for the fitting to put the plug ?
There are also breathers on the diffs right... would it be the same plug ?
Old July 3rd, 2012, 06:20 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Did you get another truck?
Old July 3rd, 2012, 08:04 AM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
It is supposed to be open I believe (unless you are wading/fording), so that it lets the oil that leaks out have somewhere to go (besides back up and soil the clutch surface).
I wonder if anyone heer has thought of (or used) a rubber plug for quick removal?
Love it, only a Rover would incorporate a design that anticipates leaking oil to such an extent that they needed a relief hole!
Old July 3rd, 2012, 08:22 AM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
It's your blue truck's young brother ;-)
ID:	53803   Click image for larger version
Old July 3rd, 2012, 03:26 PM
USLandy's Avatar
USLandy
Andrew
defender 90
breather plug, I would just plug it when off roading because it allows oils to flow out, if a breather line is installed the oils will have no where to go. you should have two of them... the other for the timing belt inspection hole, right above your axle
Old July 3rd, 2012, 04:10 PM
I've be curious as well to know if we ever figure out the thread on this...I'm guessing it's not npt or anything.
Old July 3rd, 2012, 05:36 PM
maleger
Marc-Andre Leger
Doing research on this on the web, I saw that Napa 704-1361 is suggested as a wading plug. It's M14 x 1.5. they sell for 3.64$ at the local NAPA dealer (Canadian $)
Old July 3rd, 2012, 05:58 PM
1/4" bsp.
Old July 3rd, 2012, 06:13 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
That's what I got. It's a nice Honda part with a plastic gasket. Don't worry about finding a BSP plug.
Semper Fi!
Old July 3rd, 2012, 06:48 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
I called Rovers North and ordered one. Getting it on Friday, so I'll provide part number if it works out.
Old July 3rd, 2012, 07:13 PM
maleger
Marc-Andre Leger
ordered
I ordered 4 from the local NAPA and will pick it up in the morning for about 15$ total.
Old July 3rd, 2012, 10:30 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Nice truck Gery! Looks great.
Old July 3rd, 2012, 11:39 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Thanks Clarence. It's a new beginning.
Old July 4th, 2012, 12:02 AM
I bought two plugs from Rovers North. One for the bellhousing and the other for the timing case. I have wrecked a clutch from filling the bellhousing with mud.
Old July 5th, 2012, 09:03 PM
cdb
Clark Bowen
Did the Napa plug work?
2011 RR HSE -
2001 GMC 2500 4wd
Old July 6th, 2012, 12:34 AM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
RN part number UYP500090
$8.63
Fits perfect. Probably could of got it somewhere cheaper, but was ordering other bits and pieces anyways.
Old July 6th, 2012, 05:21 AM
maleger
Marc-Andre Leger
Napa part
I hope to try it this weekend,
OBD Plug no power??? Cyborg Defender Technical Discussions 4 December 29th, 2005 11:29 PM
what does this plug in to? mattdh Defender Technical Discussions 6 November 2nd, 2004 11:59 PM
What does this plug go to??? Chris Cox Defender Technical Discussions 1 July 11th, 2004 03:24 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
97 radio plug arrangements Gkase Defender Technical Discussions 1 October 6th, 2003 06:58 PM
