short total electrical power loss while driving - Defender Source
Old November 30th, 2013, 06:41 AM
klim1981
Kim
Defender Td5 2001
Hi,
I am struggling with a problem I can't solve on my own.
While driving sometimes the dash and engine goes completely dead for a split second and continues normally again.
On some days when I try to by turning the key the alarm start to shout and there are sometimes days everything will stay completely dead. No light nothing like the battery is dead for years.
It is not due to warm or cold temperature. Long or short distance driving. I have really no clue.
If there is power, starting is not a problem at all. But as I said sometimes even during driving every thing goes black for a split second and then back to normal.
You guys have any idea where to begin?
Kim
Old November 30th, 2013, 07:03 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Originally Posted by klim1981 View Post
Hi,
Kim
Check your battery leads, ground, check for loose starter(solenoid?) connection.
Old November 30th, 2013, 07:29 AM
klim1981
Kim
Defender Td5 2001
Battery leads ok, but where/how do I check the grounds?
Thanks for your reply.
Old November 30th, 2013, 08:46 AM
Follow the negative battery cable. Also, look around under the hood for more wires that are bolted to the engine and bode or chassis.
Old November 30th, 2013, 09:07 AM
The Dro
Dro
1988 Ninety
Check the negative cable. It's the black cable from the battery to the frame/motor.
My suggestion is not to drive the truck until you find your issue. You can end up with a bigger mess if left unattended.
Old November 30th, 2013, 09:29 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
I was thinking that the ignition switch is starting to die... can you wiggle/bump the key while its running to re-create it?
Old December 2nd, 2013, 11:16 AM
D110
Jamie
1955 107
x2 - sounds like the ignition switch to me.
electrical, vin
HS2.8TGV Severe power loss. Air in fuel line? DesertRat Defender Technical Discussions 12 February 24th, 2007 08:35 AM
Total Cut Out, No Power gtg067i Defender Technical Discussions 8 May 22nd, 2006 02:18 PM
Power Radio Antenna Kimos Defender Technical Discussions 0 October 21st, 2004 08:45 PM
Electrical short with my radio ? paulb Defender Technical Discussions 4 August 11th, 2004 12:25 PM
