shop to change timing belt 300tdi - DC Metro area - Defender Source
Old June 18th, 2010, 02:10 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I was thinking about doing it myself, but I don't have the tools, time (or more importantly a place to really work on it) down in DC in my apt complex... I hate to pay another $1K into having somebody do it for me but I may not have a choice as I have no idea when it was changed last (and already had the water pump unexpectedly go).
Where does everybody recommend around here? I looked on the "get your rover fixed" forum but didn't really get an answer. Arlington Motor cars tends to have a few rovers in its lot, Loudoun Rover (said $1000), someplace else?
cost is the issue here... I'm holding off doing any actual modifications and just trying to fix/prevent as much as possible.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old June 18th, 2010, 07:26 PM
DCWhybrew
Chris Whybrew
91 RR, 05 LR3
Check bushducks.com they have a mechanics page that lists LR mechanics by state and respective cities.
06 LR3 SE
05 LR3 SE
02 DII SD7 (sold)
00 DII SE (sold)
97 RR HSE Panther Ed. (sold)
96 DI SD (sold)
91 RR (sold)
Old June 18th, 2010, 07:34 PM
Maybe Ren Ching would do it for some $$$.
Old June 18th, 2010, 07:55 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
.what are the signs if any that it is time to replace the belt?
Old June 18th, 2010, 08:22 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Bring it by my place in Woodbridge, I'll do it for you.
Semper Fi!
Old June 18th, 2010, 08:33 PM
There you go! Rover people are great.
------ Follow up post added June 18th, 2010 08:34 PM ------
It is age and miles on a diesel. On a gas motor it is a chain. They tend to last a long time (my LWB has 180k on it original one) but over 200k or so become suspect.
Old June 18th, 2010, 09:11 PM
50,000 miles
Old June 18th, 2010, 09:37 PM
Wolf Fabrication
Sterling Archer
'08 D3
When I got my truck I had no idea how many miles were on the Tdi, so I decided to replace it for peace of mind. Turns outs it was nearly brand new, but it got replaced anyway.
Make sure you do the tensioner while you are in there.
Semper Fi!
Old June 18th, 2010, 09:58 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Thats really cool of you, Thanks Jonathan.
I couldn't agree more.
Basically the same reason I'm doing it. After the water pump blew it was a bit of an eye-opener.
I'll order all the parts this week.
You guys rule
~2008 GTI TSI
Old June 19th, 2010, 12:36 AM
I would try to find a diesel shop and see if they can do it.
I'd do it if I had time but I don't, at least for a while. If you do it, get the kit with new tensioner, idler, and crank gear, change the seal and o-ring behind the crank gear, and absolutely make sure you have the timing pins for the inj. pump and flywheel.
I have heard that you can briefly run the engine with the timing cover off to make sure the belt isn't walking off the pulleys. No personal experience in that particular dept. though.
Old June 19th, 2010, 06:35 AM
Wolf Fabrication
Sterling Archer
'08 D3
You don't need pins for the injector or flywheel, just use a correct size drill bit in the injector pump and chock the wheels in neutral so the drivetrain doesn't move.
Semper Fi!
Old June 19th, 2010, 11:41 AM
That doesn't sound like best practice to me. Once you get the belt on you have to loosen the pump gear and turn the engine to line up with the flywheel notch. Locking down the IP during the belt change is just one step. If the gearbox is in neutral, what good does chocking the wheels do? Shortcuts of this type are better left for working on one's own vehicle, IMO. Sorry if that doesn't agree with you.
Old June 19th, 2010, 12:06 PM
Wolf Fabrication
Sterling Archer
'08 D3
No, you line up the timing marks first, then lock the injection pump, loosen the tensioner, then take off the old belt and put on the new one. No sense making it more complicated than need be. Either way, to each his own.
Semper Fi!
Old June 19th, 2010, 12:27 PM
Err, no. Suggest you read the manual.
Old June 23rd, 2010, 06:59 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
the complicated part is the owner having to have someone else fix it after it gets botched the first time. It's happened on here before and I've had to do several in recent history. Your doing something that will effect the engines performance for a good part of its life and once done is not just a "fiddle with this adjustment" to rectify if not correct. Scoffing at the use of correct equipment and procedure is just asking for issues. Sure you can "bush" fix, but it's not an emergency, you are (I'd assume) charging money for this service, and we are hardly in the bush eh?
Not sure why I give at shit, other than I'm getting pretty tired of fixing other peoples "bush" repairs and feeling bad for those that call with the "how come my diesel smokes and I just had it fixed".
Matt Browne
Old July 19th, 2010, 03:46 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Hey Guys,
I just got word from Jonathan (Wolf) that he's not going to be able to help me do the timing belt @ his shop.
I was planning on doing it this Saturday the 24th. Anybody who knows what their doing want to help? I'll be happy to throw some cash your way. I should have the parts in this week...
~2008 GTI TSI
Old July 19th, 2010, 05:00 PM
do you have the timing tools? I'll be out of town the next two weekends.
Old July 19th, 2010, 06:39 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
i don't have much of anything above the actual parts. Ordered it from Eric a few weeks back, should be here shortly.
~2008 GTI TSI
300tdi, tdi
300tdi timing belt change now problems discotdi Defender Technical Discussions 57 June 4th, 2009 10:10 PM
US source for 300tdi timing belt tool kit D90user Defender Technical Discussions 5 September 5th, 2006 05:35 PM
300tdi timing belt check? D90user Defender Technical Discussions 6 April 5th, 2006 07:24 AM
Need RECO on shop in Long Beach area reaper99999 Defender Technical Discussions 2 February 6th, 2006 10:24 AM
