Shocks - Nitrogen Pressure - Defender Source
Old July 13th, 2009, 06:28 PM
josecamorim
Jos Amorim
04 Defender 90 td5
Hello,
I recently fited Bilstein 7100 with remote reservoir 10" travel shocks on all four corners of my Land Rover Defender 90" . They are valved 360/80 but im not sure what is the nitrogen pressure (i believe factory Standart).
Im very happy about the overall result, the front behaves perfect, but the back still "jumps" a bit, especially when Im driving fast
The shocks are new, so i dont want to open them for now and mess with oil and seals etc. etc...
My question is: can I solve my problem by changing something on the nitrogen pressure?
What can i expect by messing with the nitrogen pressure:
More pressure=stiffer shocks???
Less Pressure=softer shocks???
Hope you guys understand my English.
Thanks for the help,
Regards,
Jos
Old July 14th, 2009, 10:59 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
YOu can increase you pressure in the back to 220 psi. and see if that helps at all. I don't think it will give you what you want though. I run 400/100 in the back of my 90 and there is no bouncing at all. Changing the valve stack is very easy to do. Take about 30 minutes. Bilstien sends you shims in the order they have to be installed so there is no guesswork. There is also a step by step guide on taking the shock apart on the website. FIrst try taking the pressure to 220 psi and see if it helps.
shocks cbkearney Defender Technical Discussions 21 January 3rd, 2007 08:40 PM
WTT! D90 doors/Fox shocks. TwisteD90 For Sale - Parts 1 October 3rd, 2005 08:33 AM
What shocks to buy? Chris Cox Defender Technical Discussions 15 July 31st, 2004 03:04 AM
How long do your shocks last? nickt Misc. Chit-Chat 10 March 19th, 2004 08:16 PM
