Shocks: Heim Joint Removal - Defender Source
Old January 18th, 2008, 06:38 PM
fleabus's Avatar
fleabus
Dan
None :(
Question Shocks: Heim Joint Removal
The heim joints in my rear Fox shocks were clunking like mad... so I bought a set of poly bushings.
Any tips on removing the old busted heim joints?
Thanks!
-Dan
Old January 19th, 2008, 08:35 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
On the Fox shocks there is a circlip on either side of the heim bearing. Remove those and press out the heim bearing and press in a new one. I think they are $20 or $25 at Polyperformance.
Old January 19th, 2008, 03:42 PM
fleabus's Avatar
fleabus
Dan
None :(
Thanks.
The circlips are already removed.
It is the 'pressing out' of the heim bearing I am having trouble with.
Already broke a C clamp... though I am pretty sure it said it was made in China
-Dan
Old January 19th, 2008, 05:15 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I use a small shop press - actually uses a jack to get the force. Not sure a c-clamp (US or china) is strong enough. You might be able to fabricate a jig for doing it, but a machine shop if you don't have access to a press.
Old January 19th, 2008, 06:31 PM
fleabus's Avatar
fleabus
Dan
None :(
That's what I was afraid you might say.
I suppose I'll have to take them to a machine shop then.
Cheers!
-Dan
Old January 26th, 2008, 07:27 PM
Ronanmd1
Jason
1997 D90 HS2.8
Which poly bushings?
Dan - Having a similar problem with my shocks. What part number/manufacturer did you use for the replacement bushings?
Cheers
Jay
Old January 26th, 2008, 07:29 PM
fleabus's Avatar
fleabus
Dan
None :(
Cheers
Jay
Here you go:
http://www.offroadwarehouse.com/prod...productID/3771
-Dan
Old January 26th, 2008, 08:05 PM
Ronanmd1
Jason
1997 D90 HS2.8
Fox Heim Bushing
Dan - Thanks, exactly what I need.
Cheers
Jay
CV Joint Removal Lriwater Defender Technical Discussions 21 September 7th, 2009 01:36 AM
shocks cbkearney Defender Technical Discussions 21 January 3rd, 2007 08:40 PM
WTT! D90 doors/Fox shocks. TwisteD90 For Sale - Parts 1 October 3rd, 2005 08:33 AM
heim joint question erik d Defender Technical Discussions 1 November 7th, 2004 06:50 PM
How long do your shocks last? nickt Misc. Chit-Chat 10 March 19th, 2004 08:16 PM
