Shocks and Spring Replacement - Defender Source
Old June 25th, 2014, 10:22 AM
richord
Richard Ordowich
1987/D90
My truck is a 1987 D90, 2.5TD with the LT77 with about 125K miles. I have no idea if the shocks or springs have ever been replaced (I suspect not).
The truck seem to handle fine even when hitting bumps. There are however numerous squeaks when I rock it.
I am about to change the A-frame ball joint and was wondering if I should next change the shocks and springs or just the shocks?
Also which shocks/springs should I use?
I do not plan any significant off road activities and the only extra weight I will carry on occasion is a front mounted snow plow that weights about 200 pounds (Someone already told me using this vehicle for snow plowing is not advisable but I will only use this occasionally for my driveway.)
Should I buy the standard shocks or aftermarket? Same question for the springs if I should replace them and if so with which kind?
Old June 25th, 2014, 10:36 AM
Your description does not make it sound like you have a need for new springs or shocks. You say you are happy with the handling. If you investigate and find that a shock is actually squeaking, then just get some stock replacements or some Monroes locally.
If it ain't broke, don't fix it. Do not start replacing suspension components unless it is broken or there is a need. The original bushings and such are a much higher quality than anything you can buy today.
I'm not sure why someone thinks it should not be used for plowing.
Old June 25th, 2014, 10:57 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
The AA & RAC in Britian many moons ago use to have a fleet of Land Rovers fitted with plows, heck I have even seen a three point hitch on the back of a S2.
A snow plow with the break-away springs is the way to go encase you hit something hard,
Enjoy
ID:	97590   Click image for larger version
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old June 25th, 2014, 11:12 AM
richord
Richard Ordowich
1987/D90
I have a bush bar with a front hitch installed on my truck and installed a K2 plow:
http://k2plows.com/
When hook it up it drops the height of the truck about an inch.
I haven't had the opportunity to use it yet.
ac
Hardtop Rear Gas Shocks Replacement Question!!! thehundredth Defender Technical Discussions 6 November 7th, 2013 06:29 PM
spring wedges/spring spacers/A arm bracket crown14 For Sale - Parts 5 September 16th, 2011 12:50 PM
Spring replacement Gardner Defender Technical Discussions 8 May 27th, 2010 12:46 PM
Koni Heavy Track Shocks +2 - Land Rover - 4 New Shocks JohnC The Vendors Loft 7 April 13th, 2010 09:34 AM
Stock D-90 replacement shocks... OCD90 Defender Technical Discussions 6 December 19th, 2003 09:25 PM
