Shock washer/bushing question - Defender Source
Old July 3rd, 2014, 07:27 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
I just bought a set of standard height Pro-Comp shocks for my Defender 90. The top & bottom of the fronts and the bottom of the rears have a threaded pin that needs 2 dished washers and 2 rubber bushings to secure them to the vehicle.
1. Do the washers &bushings go like this -)[]-[](- or like this -([]-[])- I have seen it both ways. Rovers North page shows the first, but in the photo of the shocks they are like the second. Which is it?
2. The rubber bushings have a raised lip on both sides. One side is larger than the other. Which way round so they go?
I called Pro-Comp but they couldn't help ("We don't see many Land Rovers") and I called Rovers North and endured the twat with the British accent, only to learn they're closed.
Can you help?
Thanks in advance.
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old July 3rd, 2014, 07:37 PM
I would go by the manufacturer. There should also be bushings in the inside.
Old July 3rd, 2014, 07:45 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
The shocks that are on there now have metal washers on either side of the bushings.
They came loose in a box so I had no idea what order the parts went.
But you're saying to go with -([]-[])-?
That would point to the larger lip on the outside, to contact the washer. Makes sense.
Thanks!
Paul.
Old July 3rd, 2014, 09:54 PM
The ones on the stud "cup" the bushing. Otherwise the bushings won't last. On genuine and Bilsteins and OME they have four washers for each stud end.
Old July 3rd, 2014, 11:12 PM
Like this:
-)[]-[](- this way the bush has some room to bulge as it compresses.
Old July 3rd, 2014, 11:24 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Originally Posted by o2batsea View Post
Like this:
As Bill said, PLUS the shock does rotate side to side on full axle articulation and if the washers are as in the crossed picture on the first post you could run the risk of snapping the eye off of the shock. I did have this happen once, found that outer washer had the hole elongated and was torqued to hell, to the effect that the washer was tightened up on the eye of the shock and shock mount not just the bushing sleeve.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Hand throttle washer/bolt/bushing o2batsea Wanted 4 June 11th, 2013 11:37 AM
NAS 110 Washer and Wiper Switch Question COSteve Defender Technical Discussions 1 October 21st, 2010 04:40 PM
Radius Arm Bushing Question Craig T Defender Technical Discussions 4 April 16th, 2009 09:02 PM
Bushing hardware question D90user Defender Technical Discussions 3 November 30th, 2005 03:54 PM
Panhard Rod Bushing Question JBurt Defender Technical Discussions 3 December 31st, 2004 08:45 PM
