Shock Valving - Defender Source
Old November 28th, 2012, 08:46 AM
gonzanc's Avatar
gonzanc
Nick
'95 4.2L NAS D90
Shock Valving
All:
I am going with the OME 764 springs on all 4 corners with a 1" spacer in the rear. I am wanting to go with the Fox Emulsion 2.0, but I am not sure of the length or the valving. Please list your recommendations for valving and length. FYI, I will be using the stock shock mounts and will be driving 85% on the road.
Old November 28th, 2012, 02:07 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Foxs will not work on stock mounts. Search for explanation/solution.
Old November 28th, 2012, 02:16 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
They used to make pin to pin style and pin to hoop style shocks.. not sure that they do anymore besides some other OEM applications.
Old November 28th, 2012, 03:40 PM
owen's Avatar
owen
Owen Jones
Yellow`95 D90 ST #2188
good choice. I have Fox 2 inch emulsion shocks with remotes on all four corners. Call Fox sales and they will insist on you getting the right measurements on the truck to determine the shock specs. I went with standard valving which worked well - if a tad soft at the rear.
I used a Rockware top mounts at the rear and fabbed a simple bottom bracket for the pin. Try to get the pin running at right angles to the shock, or the swivel ball will wear quickly. IMHO they are well worth the little effort to get them fitted
"I think you need a little weatherstripping - right here..."
vin
Pics of modded shock towers??? cbass Defender Technical Discussions 27 November 21st, 2008 08:52 PM
Rockware front shock mounts jorge Defender Technical Discussions 1 May 25th, 2005 11:48 PM
Old Man Emu Shock Life - and 4 questions COSteve Defender Technical Discussions 13 April 1st, 2005 04:39 PM
external front shock mounts? brianbonner Defender Technical Discussions 9 January 11th, 2005 05:06 PM
Rancho 9005 shock DBZ2009 Defender Technical Discussions 6 December 13th, 2003 10:28 AM
