shock towers/shock removal - Defender Source
Old April 28th, 2007, 09:04 AM
So I have gotten the front shock towers off and the springs out, easy. How did you guys get the top nut off the front shock? Did you just replace the shock tower? Thanks.
Old April 28th, 2007, 01:08 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I think I just used an Impact, but aren't there flats on the top of the shock piston to keep it from turning while you loosen the nut? If not and you are replacing the shock anyway, just put a set of vice grips on the piston shaft. Obviously you don't want to do this to the new shock when tightening or if you are reusing the shock as it will scar the shaft and tear up the seal on the shock when it compresses.
Old April 28th, 2007, 01:44 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Sawzall.
Old April 28th, 2007, 02:46 PM
tried all of the above. started to eat up the top with vice grips, I ended up burning out the nyloc nut with a little torch and it came right off with the plastic gone. the other side came off the first try.
Old April 28th, 2007, 07:30 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Anti sneize is your best friend
Old April 28th, 2007, 09:06 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Channel locks on the shock itself sometimes work, especially when removing the bottom bolts
Old May 8th, 2007, 08:01 AM
pmd's Avatar
pmd
Paul Dandini
None :-(
I planning to replace my shocks and shock towers later today.
In order to remove shocks I will need to sawzall/cut bolts.
I've never installed shocks before.
Any advice for removing the old shocks and installing the new?
Do you install the shocks compressed or open? ...like I said I am a neophyte.
Thanks in advance.
Paul
Old May 8th, 2007, 01:36 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
I did not have to cut anything. Impact wrench, WD40 (or equivalent; start spraying a few days before you undo everything so that it can soak good), channel locks(or strap wrench or...) and that was it. You's probably need a lot of patience. For the bottom (front?), I think I used a small wrench (5/32" ?) to keep the shock from turning.
Well.... Jack Stand and Hydraulic jack! ;-) Also take that opportunity to remove the rust everywhere (shock towers, retaining rings,...) and apply some anti-rust coating/something while everything is undone.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old May 8th, 2007, 06:28 PM
pmd's Avatar
pmd
Paul Dandini
None :-(
Thanks - got it done - only needed to cut two bolts - a Plumbers wrench worked well on the old shocks..
Paul
Pics of modded shock towers??? cbass Defender Technical Discussions 27 November 21st, 2008 08:52 PM
Rockware front shock mounts jorge Defender Technical Discussions 1 May 25th, 2005 11:48 PM
Old Man Emu Shock Life - and 4 questions COSteve Defender Technical Discussions 13 April 1st, 2005 04:39 PM
For Sale: Mantec Steering Guard, NSO Rear Shock Mount, Hinged Radius Arm Doogs For Sale - Parts 8 January 26th, 2005 11:28 AM
Rancho 9005 shock DBZ2009 Defender Technical Discussions 6 December 13th, 2003 10:28 AM
