shock towers - Defender Source
Old August 19th, 2017, 08:18 AM
jrod770
jerid davies
1984 110
shock towers
Time to do springs, shocks, and towers on my 110. Is there any benefit to using the Terrafirma towers, or just use OEM?
Old August 19th, 2017, 08:27 AM
Naplm00
Matthew
The tubular one certainly look better I have them on my truck and they're definitely stronger you only real benefit though is that it's easy to put the shock in and out
Old August 19th, 2017, 08:31 AM
Factoid's Avatar
Factoid
Mark
Three criminals seeking revenge
I went with the terrafirma as my oem were beat up and I liked the look. They are VERY beefy and look great. What they don't tell you is you may have to trim the inner fender liners. I ended up cutting a two inch section out on the right side and the left side fit fine. I'm pulling my engine in a couple weeks and plan to weld the strip back in. Also, remember that the real stress is on the spring mounts, not the shock mounts.
So, unless your oem are trashed or you need extended travel or you just like the look, oem is fine.
1976 Series III 109 "Montoya" ("You killed my father, prepare to die")
1988 Defender 90 LHD "Vizzini" (speed demon from Sicily)
1987 Defender 90 MOD LHD "fezzik" (giant rock thrower)
1975 Porsche 911 hot rod
1964 Porsche (Beck) 904
Old August 19th, 2017, 08:56 AM
I personally would go tubular if you're buying new towers.
If you're not buying new towers, then don't bother
Old August 19th, 2017, 10:10 AM
Make sure to buy new heavy duty rings with the tubular ones. I have both, sort of dig OEM once galvanized.
Old August 19th, 2017, 10:13 AM
Naplm00
Matthew
I'm surprised you had to change your inner Fender liners. Mine didn't even come close
Old August 19th, 2017, 11:06 AM
imola's Avatar
imola
2nd that, you don't need to trim the inner fender liners with terrafirma towers.
Old August 19th, 2017, 08:32 PM
jrod770
jerid davies
1984 110
Yes, my stock towers are rusty and need to be replaced. I saw the Terrafirmas, and after searching, could not find any reviews. I am torn to go with oem galvanized and the Terrafirmas.
RTE adjustable shock towers hoxie173 Defender Technical Discussions 3 March 2nd, 2014 09:08 AM
Galvy shock towers... o2batsea For Sale - Parts 9 October 1st, 2013 04:33 PM
Pics of modded shock towers??? cbass Defender Technical Discussions 27 November 21st, 2008 08:52 PM
16x10 steel wheels/DiscoII shock towers WillT Wanted 6 August 2nd, 2005 01:12 PM
Galvanized stock shock towers... dmarchand For Sale - Parts 1 May 22nd, 2004 04:28 PM
