shock suggestion - Defender Source
Old June 7th, 2010, 12:45 AM
bennett's Avatar
bennett
Bennett
'97 Defender 90 Soft Top #1140
shock suggestion
While i was seriously looking forward to putting a full OME setup on my truck, I just moved into a new place where i only have about an inch of clearance in the garage. Given the slight lift OME springs would give me, looks like those wont work for me. Anyone have suggestions for shocks that will work with stock springs? I wasn't sure if the Bilsteins or Fox Shox would work without raising up the truck.
Guess a new roof rack will have to wait till i move again...
Old June 7th, 2010, 12:53 AM
Bilsteins tighten up the ride quite a bit. I have them on all my trucks except for the D90 (had OME when I got it). Chicky (my 1995 D90) had bilsteins and I liked them better.
Old June 7th, 2010, 12:59 AM
bennett's Avatar
bennett
Bennett
thanks Ron. Any idea if Chicky needed new shock mounts or did they fit a stock setup?
------ Follow up post added June 6th, 2010 10:04 PM ------
oh, and any idea if it had the upgraded bushings?
Old June 7th, 2010, 07:01 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Bilsteins fit stock shock mounts with no modifications reguired - I have had them on my D-90 and my old 91 Range Rover. I have also broken two rear Bilsteins - top mount on one and bottom mount on another.
My dream shock is a set of the Koni Raids but they are $$$$
Old June 7th, 2010, 11:03 AM
They just bolt up. I used the bushing that came with them.
Old June 7th, 2010, 11:26 AM
Rugbier's Avatar
Rugbier
Gustavo
OME shocks won't give a lift , and they are nice ride.
NO SIGNATURE
Old June 7th, 2010, 12:18 PM
minor point that doesn't really answer your question- just reiterating that it is a common misconception that a spring lift allows you to fit longer shocks. It doesn't, plain and simple. You have to raise the top mount or lower the bottom mount to do that, or put in longer bumpstops. Otherwise you will be breaking shocks. If you ever go offroad or hit any potholes, that is.
Old June 7th, 2010, 12:25 PM
You can use the OME shocks with the stock springs. They are a bit longer but still work with the stock mounts without bottoming out.
Old June 7th, 2010, 03:14 PM
bennett's Avatar
bennett
Bennett
Good to know, thanks guys. I was just afraid that the extra height the OME springs gave would be required for the shocks. Guess im wrong, which is good to know
Pics of modded shock towers??? cbass Defender Technical Discussions 27 November 21st, 2008 08:52 PM
Rockware front shock mounts jorge Defender Technical Discussions 1 May 25th, 2005 11:48 PM
Old Man Emu Shock Life - and 4 questions COSteve Defender Technical Discussions 13 April 1st, 2005 04:39 PM
Scorpion racing Rear upper shock mounts for stock trucks! dmarchand For Sale - Parts 2 July 8th, 2004 12:57 PM
Rancho 9005 shock DBZ2009 Defender Technical Discussions 6 December 13th, 2003 10:28 AM
