Shock Questions - Defender Source
Old August 18th, 2016, 08:37 AM
RoverNY
Darrell
1987 Defender 90 ex-MOD
Shock Questions
Hello All,
I am putting the finishing touches on the restoration of my 1987 ex-Mod D90 and I am running into some "conflicting" information regarding the selection of my new shocks. After some research, I have selected a set of Koni shocks and the part numbers that the Koni NA site suggests are:
8240-1181SPX - Front
8240-1182SPX - Rear
The distributor in the UK contacted Koni - Holland and received confirmation that the fitment for "my vehicle" would be:
8240-1190SPX - Rear
When I look at the 8240-1190SPX on the Koni site, this shock comes back for fitment for a 110.
The distributor commented that:
"This uses the same fitting at the bottom pin as the 90 model"
I was hoping that some members have run into these same issues and could confirm which shock would work for my application.
Thanks again,
Darrell
Old August 18th, 2016, 04:38 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Fitment is the same but load for the shock may be different.
Land Rover 110
Old August 18th, 2016, 04:43 PM
IIRC, the 1190 have a bit longer travel and they told me the valving was similar to the 1182. I unfortunately lost the email with the information. see if the distributor can tell you. I'm running the 1190 on my 90 and they are fabulous.
Old August 18th, 2016, 05:51 PM
RoverNY
Darrell
Hello All,
I received an update from the distributor in the UK who stated: "I have checked the bump and rebound rates between the two and although they are different its marginal and would not transfer into how the vehicle rides." So it sound like the distributor is confirming that the differences between these two shocks are small and would not affect the ride/handling on my D90. So with that said, I am confirming my order "over the Pond"...I appreciate all for your thoughts and input....Darrell
Lowered rear shock mounts, shock mount for spacers, and HLC Fab cones Jake1996d1 For Sale - Parts 3 October 13th, 2011 03:14 PM
Fox/Bilstein shock questions d90dan Defender Technical Discussions 3 September 19th, 2009 01:21 PM
shock towers/shock removal rover4x4 Defender Technical Discussions 8 May 8th, 2007 06:28 PM
Old Man Emu Shock Life - and 4 questions COSteve Defender Technical Discussions 13 April 1st, 2005 04:39 PM
Shock Help Britt Easterly Defender Technical Discussions 5 November 25th, 2003 10:13 AM
