shock pin dimensions - Defender Source
Old June 2nd, 2014, 01:15 PM
Anybody able to provide the dimensions A,B,C, and D as per the attached photo? I'm sending my fox 2.0's in for rebuilding and the pins were too long when I installed them the first time around. Looking to have new ones made that match the stock pin dimensions so that I can use factory style bushings.
This is for the lower mounting point on the front shocks. AFAIK should be the same 90/110/130 D1,RRC (coil not air) etc
Thanks!
DB
Name:	Shock Pin Dims.jpg
Old June 2nd, 2014, 01:20 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Give me a few minoots.
Old June 2nd, 2014, 02:13 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Old June 2nd, 2014, 02:57 PM
perfect. doesn't get much better than that, thanks Zack!
Old June 2nd, 2014, 03:16 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Someone needs a digital caliper.
Old June 2nd, 2014, 03:20 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
The digital one didn't have batteries
Old June 2nd, 2014, 03:25 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I think it'd have been better with a fisheye lens...
Rent my
Hella Euro 7 Pin to 4 Pin Trailer Wiring Adapter Wolf Fabrication For Sale - Parts 2 February 28th, 2013 02:57 PM
Lowered rear shock mounts, shock mount for spacers, and HLC Fab cones Jake1996d1 For Sale - Parts 3 October 13th, 2011 03:14 PM
D90 caliper brake pin - cotter pin help Gardrover Defender Technical Discussions 4 May 29th, 2009 02:01 AM
shock towers/shock removal rover4x4 Defender Technical Discussions 8 May 8th, 2007 06:28 PM
Need help with some dimensions.... tbmcneill Defender Technical Discussions 18 May 4th, 2004 04:14 PM
