shock mount - Defender Source
Old January 18th, 2006, 08:55 AM
redrover
Guest
Posts: n/a
shock mount
Sometime ago I saw a pic of a front lower external shock mount bracket that bolted into the panhard bolt and control arm bolt. The bracket was L shaped. Does anyone remember seeing it? JP
Old January 18th, 2006, 11:11 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I think SG might have them. Mine are weld on from Rover Tracks
Legend in My Own Mind.
Old January 18th, 2006, 11:15 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Also, AB sells a relocation tower with lower external shock mount. I think they sell it as a dual shock kit but could be used for outter shock mounting alone I would think.
https://www.roverparts.com/ProductLi...tNumber=BA2157
Chris von C
[/size]
Old January 18th, 2006, 11:42 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Or you could get the parts from an air suspension equipped Range Rover Classic - the shock was mounted externally on those trucks because the air bag is in the standard spring location.
Old January 18th, 2006, 02:58 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
JP, is this for your truck? Be careful. All of the bolt on stuff is kind of flimzy for wheelin...
Old January 18th, 2006, 05:12 PM
This is something that I have been wanting to do also... If the bolt on stuff is weak, what do you recommend?
I looked at SG, they wanted $350.00 plus shipping. I did not remember seeing anything on RoverTym or Rockware.
If someone has a custom pair or a set of plans, let me know.
Old January 18th, 2006, 06:53 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
What is the advantage of relocating the front shocks outside the spring? I am just curious>
Joe
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old January 18th, 2006, 09:52 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
Pendy made me a set. maybe he'll chime in; however, he has explained it as a custom job. They need to be measured and made specific for that truck.
Joe
Longer shock i.e. more travel
better shock choices
don't have to remove spring to replace shock/don't have to remove shock to replace spring
ID:	4829   Click image for larger version
Name:	bjyht 006copy.jpg
Originally Posted by MuddyOval
Sheki, you are a wang too.
A wang is another word for, you guessed it, A DICK!
Nothing racist, just pure DICK!
Old January 19th, 2006, 08:09 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Mine look similar to Davids. Rover Tracks makes them very beefy. The tops bolt on and you just have to weld or have someone weld the bottom stud on for you. Very easy.
Lots more travel. I run 14" travel shocks up front to match the rear.
Also can run eye to eye shocks.. no posts to snap off. also a lot easier to change
ID:	4837   Click image for larger version
ID:	4839   Click image for larger version
Old January 19th, 2006, 08:22 AM
redrover
Guest
Posts: n/a
Thanks for replys guys. I made my own a few yrs ago but am now going to need to add another tab to experiment with a front anti rock style swaybar. There is not much room to squeeze all this junk in. JP
mount
Rear shock mount bracket WhiteD90 For Sale - Parts 0 June 5th, 2008 10:04 PM
Loop mount front shock tower? cellulararrest Defender Technical Discussions 19 March 17th, 2008 09:20 AM
External front shock mount ini88 Wanted 0 March 25th, 2007 11:12 PM
Rear Shock Mount Drop Kit mffoster For Sale - Parts 3 January 10th, 2007 10:05 AM
For Sale: Mantec Steering Guard, NSO Rear Shock Mount, Hinged Radius Arm Doogs For Sale - Parts 8 January 26th, 2005 11:28 AM
