Shock Install Advice - Defender Source
Old June 28th, 2006, 03:49 PM
Grover's Avatar
Grover
Question Shock Install Advice
I just received a new set of shocks and a steering damper from AB (they have a sale on Bilstein shocks till 7/7) Anybody out there have any hints on installing shocks on a stock D90? I searched D90 Source and didn't find any info...
Old June 28th, 2006, 04:25 PM
Get a giant pair of channel locks and wedge them against the tire to undo the bottom nut. Then undo the four little nuts on the tower and with the entire tower out repeat for top nut. Anticipate replacing both retaining rings that have the four nuts on them.
Old June 28th, 2006, 04:37 PM
Grover's Avatar
Grover
Why would I have to replace the retainer ring?
Old June 28th, 2006, 05:09 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Why would you remove the shock tower?
Jack up the front of the Rover by the frame and drop the shock out of the spring. Slip the new one in the same way. Takes half the time of taking the tower off.
Email:
Old June 28th, 2006, 09:05 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
A sawzall is a really handy tool, so is an angle grinder.
If the shocks are 10 years or more old you may find out.
Old June 28th, 2006, 09:09 PM
Grover's Avatar
Grover
Well I just replaced the rear shocks and the steering damper. It was much easier than what I ahd thought. Only took about an hour.
Mike,
You recommend jacking up the front of the truck and removing the front shock through the spring. Do I need to remove the sway bar in order to drop the axle far enough to remove the shock? Is the spring somehow fastened to the shock tower? I don't want to be "wearing" a spring around my head this weekend
Anyway thanks for the advice...
Cheers
Old June 28th, 2006, 09:16 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
The spring is retained by the shock, it is not attached to the shock tower. One you detach both shock end nuts both the spring and shock can be withdrawn with enough droop. If you drop the front axles to slip the shock out, be sure to keep an eye on the brake lines, you CAN overextend them.
Old June 28th, 2006, 09:27 PM
ECR's Avatar
ECR
Yes, it is easier if you drop the sway bar away, just the 4 bolts that hold it to the frame and then rotate it down out of the way. With the front end drooping the spring is under little to no pressure and it will not kill you. A little pressure down on the axle and it will slip out. The suspension bushings will bind everything enough that you will not need to worry about breaking a brake line, there will be little to no tension on them in a D90.
Its not really that doing it this way is a whole lot easier the first time... it is easier because you don't risk breaking the tower retainer ring and such (common), and once you do it a few times it gets really fast. If your towers are rusted and damaged looking though, you might check them carefully and consider replacement... they do hold the upper part of the shock in place.
and yes, a torch or sawzall is great for lower shock nuts. Be sure to coat the new ones with a Never-Seize type product so that when you do this again down the road everything will come apart easily.
Have fun.
Email:
Old June 28th, 2006, 09:40 PM
Grover's Avatar
Grover
Good advice Mike. I appreciate it...
Old August 25th, 2006, 09:30 AM
how do you like the bilsteins?
Old August 25th, 2006, 08:27 PM
Grover's Avatar
Grover
Thumbs up
The Bilstiens are great and worth every penny! My shocks were original LR and were pretty much dead...I could compress them by hand which made the removal easy.
Cheers...
Old September 9th, 2006, 09:42 PM
Shake
Bob Hanson AKA Two-Socks
Red 94 D-90 #428
Dittto on the grinder and sawzall! Just bought my first grinder and more blades. Damn rust.
Pics of modded shock towers??? cbass Defender Technical Discussions 27 November 21st, 2008 08:52 PM
New Shock Absorber advice ecmgbob Defender Technical Discussions 1 August 27th, 2007 11:22 AM
Need suspension advice fleabus Defender Technical Discussions 2 January 20th, 2006 09:18 AM
Shock advice? roverboy Defender Technical Discussions 8 February 19th, 2004 06:11 PM
Rancho 9005 shock DBZ2009 Defender Technical Discussions 6 December 13th, 2003 10:28 AM
» Defender Registry
Rangie
pl626
MDGSCAR
Bricktop
Add your Defender
