Shock Help - Defender Source
Old November 24th, 2003, 11:08 PM
Britt Easterly
Britt Easterly
97 Defender 90
Question Shock Help
I was at a 4X4 shop (I wont mention any names) (4 wheel parts) and was looking at getting a set of Rancho 9000 adjustable shocks. They said that they don't make them for the D90. How could this be? I readily admit I know squat when it comes to most automotive things but I found this strange. Can some one point me in the right direction (size, model #) of the RS9000 so I can get a set. Thanks
Old November 25th, 2003, 07:14 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
RoverTym lists these as the Ranchos they keep in stock for Rovers. I don't know it you would need adapters for some or all of them as I have never run a set myself.
RS 99005
RS 99207
RS 99234
RS 99012
RS 99251
RS 99014
Chris von C
[/size]
Old November 25th, 2003, 08:09 AM
I suggest switching the front shocks from the pin type mount to the eye type mount.I had Rancho pin types on my 90 and they both broke at the bottom pin resulting in no front shocks.
Here is a thread that some of the guys here helped me with the problem. Thanks Guys!
http://www.defendersource.com/discus...tml?1052244497
Old November 25th, 2003, 08:17 AM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
Mike, what shocks did you end up with?
Originally Posted by Mike Hippert
I could run circles around Dave Souzas 90
Old November 25th, 2003, 08:19 AM
souza's Avatar
souza
Dave Souza
Just saw your bio... Fox remotes? What do you think of them? Are the eye to eye? Which adapters did you get if so?
Old November 25th, 2003, 10:13 AM
They are eye to eye. They give a nice ride on road and off road they seem to be adjusted just right. they allow good travel and they don't let the front end bounce at all. There is a link in the link above that has the mounts that I ordered.
Mounting the remotes and using stock shock towers is not to easy. You have to separate the shock from the remote, drill a hole in the tower, install the shock in the tower, pass the hose for the remote threw the hole and attach it to the shock. Once all of that is together I had the shock pressurized to 200 psi then I installed them on the 90.
Pics of modded shock towers??? cbass Defender Technical Discussions 27 November 21st, 2008 08:52 PM
Rockware front shock mounts jorge Defender Technical Discussions 1 May 25th, 2005 11:48 PM
Old Man Emu Shock Life - and 4 questions COSteve Defender Technical Discussions 13 April 1st, 2005 04:39 PM
Scorpion racing Rear upper shock mounts for stock trucks! dmarchand For Sale - Parts 2 July 8th, 2004 12:57 PM
Rancho 9005 shock DBZ2009 Defender Technical Discussions 6 December 13th, 2003 10:28 AM
