shock help - Defender Source
Old May 4th, 2004, 09:44 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
shock help
Quick question: I am putting in new springs and shocks at the moment. But I am having trouble just getting the front shocks out. I have been under the assumption that I take the bottoms out first, but when I get a wrench around the bottom bolt the whole shock turns. I realized that this is probably an easy question. And I have infact replaced shocks on other vehicles before, but I cannot get this one to stop turning. In short, how do you get the front shocks out? Thanks, Mike
Old May 4th, 2004, 09:50 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Just get a pair of vice grips and use these to stablize the shock while you ratchet the bolt off. However, if you sinch down too much you run the risk of crushing/denting the shock. OME have a serrated ring at the end of each shock that provides extra grip for such usage. Hope this helps.
DJ
Old May 4th, 2004, 10:01 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Try a strap wrench
Old May 4th, 2004, 10:41 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I used a pipe wrench.
Jimmy Buffett
Old May 5th, 2004, 12:53 AM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
thanks for the quick response guys. I used a combo of the strap and wrench. I was amazed to find that the front-right shock came out with no trouble at all. Tomorrow: the back end. Any words of wisdom? Thanks again all, Mike
Old May 5th, 2004, 01:51 AM
loykd's Avatar
loykd
Ken Loy
much easier Mike, since the shocks are outside of the springs. I think you started with the more difficult ones, to tell the truth. If you've got the front done, the rear will be no problem. Only thing I could suggest would be to spray rust eater or WD-40 on there tonite so the bolts will be easier to loosen tomorrow.
Old May 5th, 2004, 02:38 AM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Thanks loykd, I sprayed everything with some Gunk a while ago. I did the front first because I will be working by myself tomorrow. I was thinking the back would be easier to do by myself than the front.
Pics of modded shock towers??? cbass Defender Technical Discussions 27 November 21st, 2008 08:52 PM
Rockware front shock mounts jorge Defender Technical Discussions 1 May 25th, 2005 11:48 PM
Old Man Emu Shock Life - and 4 questions COSteve Defender Technical Discussions 13 April 1st, 2005 04:39 PM
Scorpion racing Rear upper shock mounts for stock trucks! dmarchand For Sale - Parts 2 July 8th, 2004 12:57 PM
Rancho 9005 shock DBZ2009 Defender Technical Discussions 6 December 13th, 2003 10:28 AM
