Shock bushings or new shocks - Defender Source
Old August 28th, 2011, 06:54 PM
dnp
David
1995 Defender 90
I searched the forums and found nothing that directly addresses the questions I have.
My 95 D90 ST just turned 100,000 miles, I recently noticed a clunking coming from the rear of the truck. I looked around back there, and I noticed my lower rear shock bushings on the passenger side had turned to, well, like a sticky tar! I've seen bushings get hard and cracked before, but I've never before seen bushings that look like they'd been put in an oven........
In any event, the shocks on the truck appear to be original, and they seem to work fine (totally stock suspension). Therefore, I went in search (locally) for some replacement bushings, and they were nowhere to be found.
My questions are:
(a) Do any of you know where I can find some replacement bushings (preferably rubber, not polyurethane) without having to buy complete shocks? I've looked and can't find any (and, while I ordered some replacements from a well-known Rover parts supplier, they sent me replacements for a different style shock......CRAP! They've sent me wrong parts before, so it was not a big surprise.)
or
(b) With this truck having 100K on it now, even though I'm going to leave the suspension in stock form, would I be better off going ahead and changing the shocks now? Again, the shocks that are on it work fine now, but if the factory shocks have a known life span, I'm wondering if it might be better to toss them and go with new replacements.
I realize that's a long post for a simple problem, but I'm hoping some of you with more D90 experience than me can point me in the right direction. Thanks.
Old August 29th, 2011, 10:40 AM
DesertRat
Bryan Barnes
95 D90 2.8TGV
At 100K miles I think you can't go very far wrong by replacing the shocks
with new ones.
Just my $.02.
-Bryan
Old August 29th, 2011, 10:46 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Change the shocks.
Old August 29th, 2011, 10:51 AM
dnp
David
1995 Defender 90
OK. Is the general consensus (on a factory ride height vehicle) Bilstein, OME or other?
Old August 29th, 2011, 02:22 PM
Bilstein
Old August 30th, 2011, 01:38 PM
DesertRat
Bryan Barnes
95 D90 2.8TGV
I just put OME springs and shocks on mine (2" lift) and I'm pretty happy so far.
I'm with Bill on the Bilsteins though for stock suspensions. I ran those for the last
100K miles and was happy with them as well.
-Bryan
Old August 30th, 2011, 02:35 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
I am impressed that you got a 100k out of the stock suspension. Mine was absolutely toast at 70k.
bushings
Shocks and Bushings bjf Defender Technical Discussions 23 June 17th, 2010 09:11 AM
Bilstein shocks and bushings themaxx Defender Technical Discussions 3 October 29th, 2006 04:07 PM
Removing front shocks Trevor Tarr Defender Technical Discussions 5 April 10th, 2005 04:51 PM
Why Dual shock set up? sflash868 Defender Technical Discussions 11 February 28th, 2005 02:34 AM
Scorpion racing Rear upper shock mounts for stock trucks! dmarchand For Sale - Parts 2 July 8th, 2004 12:57 PM
